RV.Net Open Roads Forum: Beginning RVing: Correct inflation of trailer tires
 > Correct inflation of trailer tires
drsteve
Michigan
Posted: 07/30/19 08:06am Link  |  Quote  |  Print  |  Notify Moderator
Optimistic Paranoid wrote:
sgfrye wrote:
drsteve wrote:
Inflate to max inflation as shown on the sidewall.
x2
no need to overthink it. has worked for me. autos, boat trailer tires, and motorcycles
As far as cars, vans, pickups, and motorized RVs go, inflate your tires to maximum and go to a mall before it opens. Use a piece of chalk to put a line across each tire, and drive a couple of hundred yards. Then check your tires. In most cases - depending of course on your vehicle weight - I think you will see that the chalk is worn off in the center, but not at the edges, which indicates that not all of the tire tread is making contact with the road.
It seems self-evident to me that this is NOT optimum for either steering traction or braking in the shortest distance. And I suspect you will also be more prone to hydroplaning in the wet than if your tires were making complete contact with the road.
Both Goodyear and Michelin have downloadable RV tire publications, available here:
Recreational Tire Care Guide
RV Tire Guide
They both warn against overinflating tires because of lessened traction, braking and steering.
BTW, the Michelin Guide also says that an overinflated tire is more prone to impact damage
I am talking only about tires on a towable. Max sidewall inflation has been working for me for 30 years. No tire problems on my TT, ever.
1991 Palomino Filly PUP
pitch
NY
Posted: 07/30/19 08:20am Link  |  Quote  |  Print  |  Notify Moderator
Inflate your ST's to max to get maximum use.
Who the hell weighs each side? What do you do adjust your inflation because the gallon of milk you drank has changed the formula?
Why do some have to make everything an exercise in engineering? Now if you have 7 anvils over the left side maybe you should look at lateral scaling,other than that, eh maybe not all that important.
OMG we are down to less than half fresh water, pull over and adjust the inflation before we burst into flames and die!
Some of you guys could suck the fun out of an Ice Cream Social!
Posted: 07/30/19 10:15am Link  |  Quote  |  Print  |  Notify Moderator
sgfrye wrote:
x2
Fwiw, that’s actually under thinking it by a good margin.
BillyBob Jim
US
Posted: 07/30/19 10:36am Link  |  Quote  |  Print  |  Notify Moderator
That's a good one LOL. [emoticon]
Optimistic Paranoid
East Nowhere NY
Posted: 07/30/19 04:31pm Link  |  Quote  |  Print  |  Notify Moderator
I know. That was directed towards the OTHER guy, who apparently runs his CAR tires at max inflation . . .
Planning
Idaho
Posted: 07/30/19 06:07pm Link  |  Quote  |  Print  |  Notify Moderator
Per Goodyear:
"...it is recommended that trailer tires be inflated to the pressure indicated on the sidewall of the tire. Trailer tires experience significant lateral (side-to-side) loads due to vehicle sway from uneven roads or passing vehicles. Using the inflation pressure engraved on the sidewall will provide optimum load carrying capacity and minimize heat build-up."
Reams of information here by a tire engineer supporting sidewall cold inflation pressure as being optimum to reduce interply shear.
http://www.rvtiresafety.net/search/label/Interply%20Shear
With tires on multi-axle trailers, like RV trailers, the belt (interply) shear forces can be 24% higher than the belt shear forces of identical size, load and inflation tires on a motorized vehicle.
The internal structural forces are different for torque than for high "slip angle" which is the situation in trailer application. Front tires on cars, motorhome or tow vehicles experience slip angle usually in the 1° range while trailer tires are subject to angles in the 10° and greater range. The forces are NOT linear. 10° can generate significantly more shear than 1°.
2016 AF 29-5K; 2016 F350 6.7, 4x4, CCLB DRW
TravelinDog
Nevada
Posted: 08/06/19 02:24pm Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
sgfrye wrote:
x2
Some people just like to overthink and complicate everything.[emoticon]
