RV.Net Open Roads Forum: Class A Motorhomes: Trailer wiring
Timothy2001
Full Timing for Now
Posted: 07/29/19 10:34am Link  |  Quote  |  Print  |  Notify Moderator
Realizing there are many different reasons the lights do not work on a trailer, are there any most likely causes on the RV side. Trailer has tested to be working fine. It’s a standard Chrysler female receptacle and I k it I am reaching but maybe it’s something simple. Maybe a separate fuse? Flashers and directional don coach work.
2008 Itasca Meridian 39z
enblethen
Moses Lake, WA
Posted: 07/29/19 11:32am Link  |  Quote  |  Print  |  Notify Moderator
Power normlly comes off the rig's house battery for lights and appliances.When connected to shore power the converter should power the 12 volt system.
Common problem is dead trailer battery followed by blown fuse or tripped circuit breaker.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
opnspaces
San Diego Ca
Posted: 07/29/19 11:36am Link  |  Quote  |  Print  |  Notify Moderator
Asking about the trailer only, which lights are not working? Are you talking the exterior running lights? How about the brake stop and turn signal lights on the trailer, do they all work?
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
MountainAir05
New Mexico
Posted: 07/29/19 11:59am Link  |  Quote  |  Print  |  Notify Moderator
HAS a trailer every been hooked up the the Rv.
Flute Man
Payson, Arizona
Posted: 07/29/19 12:10pm Link  |  Quote  |  Print  |  Notify Moderator
My coach has separate fuses for the trailer. Mine are located in one of the basement compartments near the rear end of the coach.
Jerry Parr
* This post was edited 07/29/19 12:26pm by Flute Man *
Jerry Parr
05 Mandalay 40B
Cat C7 350
04 Honda CR-V
Ham Radio K7OU
Retired EE
Jrparr32@gmail.com
602-321-8141
Full-timer
midnightsadie
ohio
Posted: 07/29/19 12:39pm Link  |  Quote  |  Print  |  Notify Moderator
and the ground wire is a real trouble maker , before you jump into cutting etc ,pull the ground wire off the frame clean reinstall. the ground can cause alot of strange things to happen.
schlep1967
Harrisburg, PA
Posted: 07/29/19 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
Have you cleaned the contacts on both the plug and receptacle?
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
enblethen
Moses Lake, WA
Posted: 07/29/19 02:04pm Link  |  Quote  |  Print  |  Notify Moderator
What works and doesn't work?
Are you talking stop, turn and tailights or interior system?
if you are talking running lights, Have "you" tested from the trailer connector by jumpering between contacts in connector?
Does your tow vehicle have amber turn signals? Does trailer have red turn signals?
if yes, look for a tailight converter.
Have you tested rig?
Timothy2001
Full Timing for Now
Posted: 07/29/19 02:08pm Link  |  Quote  |  Print  |  Notify Moderator
Everything on the rig works, nothing on the trailer works. No power at all to harness 30 amp breaker/fuse is good. Trying to track down power source now, wiring diagram not proving to be helpful.
Executive
Posted: 07/29/19 02:47pm Link  |  Quote  |  Print  |  Notify Moderator
Hopefully this is the diagram you're using.
A Simple Act of Caring Creates an Endless Ripple
Dennis and Debi Eleven Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
