RV.Net Open Roads Forum: Outdoor GFCI outlet trips when using electric cooktop
 > Outdoor GFCI outlet trips when using electric cooktop
JRscooby
Indepmo
Posted: 07/30/19 05:08am Link  |  Quote  |  Print  |  Notify Moderator
It was explained to me the breakers are to protect things from fire. The GFI is to protect you from shock. When a GFI trips, it might be a bad GFI, but make sure your kids and dogs assume that it is the appliance is bad.
road-runner
Oregon
Posted: 07/30/19 09:58am Link  |  Quote  |  Print  |  Notify Moderator
This is a really good explanation. Anybody should be able to understand what it's saying.
2009 Fleetwood Icon
harley4275
Belle River, On
Posted: 08/12/19 08:07pm Link  |  Quote  |  Print  |  Notify Moderator
Mine is the samee...just plug it into a different plug ,that is not on gfi, with an extention cord.
2013 Sunset Trail 25RB TT
2015 Silverado 2500HD 4x4 6.0 l gasser.
Equilizer 4 pt
From Belle River, Ontario
2003 Mountain Star 890sbrx Truck Camper
beemerphile1
Ohio
Posted: 08/13/19 02:21pm Link  |  Quote  |  Print  |  Notify Moderator
I disagree, the GFCI is there to save lives. The cooktop is probably defective and should be tossed.
2018 Keystone Cougar 26RBS
JRscooby
Indepmo
Posted: 08/14/19 05:17am Link  |  Quote  |  Print  |  Notify Moderator
I'm not real strong on the "toss", but somebody that knows what they are doing to check for small short. But if it is more important to use than to be safe, keep kids, dogs and other important things away from it.
CA Traveler
The Western States
Posted: 08/15/19 06:00pm Link  |  Quote  |  Print  |  Notify Moderator
It could cost more to repair than to replace the unit.
I would hope that a rational person would consider it more important to be safe. GFCIs are designed to protect you from potential electric shock. To me this trumps any "use" consideration.
2014 Grand Cherokee Overland
Bob
harley4275
Belle River, On
Posted: 08/16/19 08:00pm Link  |  Quote  |  Print  |  Notify Moderator
Ok guys . So .i pluged mine into a regular plug. My bad ... How many campers or tenters plug an extention cord into the 15a plug on the pedistal (that is not a gfci ) and run griddles ,kettles and coffee makers off that .
whjco
Lexington, KY
Posted: 08/16/19 08:21pm Link  |  Quote  |  Print  |  Notify Moderator
You could possibly have a heating element going bad in the cooktop unit that's allowing AC current to leak to ground thereby tripping the GFI.
Bill J., Lexington, KY
2006 Starcraft 2500RKS 25' Travel Trailer
2015 Ram 2500 Big Horn 6.7 Cummins.
beemerphile1
Ohio
Posted: 08/16/19 08:39pm Link  |  Quote  |  Print  |  Notify Moderator
I would be very suspicious of a campground that has such an outdated electrical system the the 15/20a receptacles are not GFCI protected. I haven't seen that for ages.
JRscooby
Indepmo
Posted: 08/17/19 09:22am Link  |  Quote  |  Print  |  Notify Moderator
This is likely true. If I had the issue, I would test with a meter. Any sign of contact to ground, I would take it apart. Working on a dead animal, so nothing to loose. Looking from inside, if don't see a loose connection or worn insulation toss the pieces. I might learn something, and I can be sure nobody gets hurt trying to use it.
Same hope, but no faith. Protect the valuable. LOL
