RV.Net Open Roads Forum: Special Trailer Brakes Required in Canada?
Open Roads Forum  >  RVing in Canada and Alaska  >  Canada
 > Special Trailer Brakes Required in Canada?
shum02
Burlington ON CDA
Posted: 07/30/19 05:06am Link  |  Quote  |  Print  |  Notify Moderator
Very more than likely if you conform to your local State laws and regs you will be fine here as we are when we travel in your neck of the woods. Ontario requires trailer brakes on trailers over 3000lbs.
You will NOT find anyone here in Ontario doing any inspections on out of country trailers except maybe around the Victoria Day weekend and only on major highway off ramps.
2006 F350 Lariat FX4 CC 4x4 PSD
2007 KZ2505QSS-F Outdoorsman
Jack_Diane_Freedom
Milton Ontario Canada
Posted: 07/30/19 05:47am Link  |  Quote  |  Print  |  Notify Moderator
Trailer brakes in Canada must be used only in metric.
cross21114
Baltimore, MD, USA
Posted: 07/30/19 05:51am Link  |  Quote  |  Print  |  Notify Moderator
wilber1 wrote:
It's a provincial thing.
BC Regulations
Trailer Brake Requirements
Gross trailer weight of 1,400 kg (3,080 Ibs) or less – Brakes are required if the trailer and its load weigh more than 50% of the licensed weight of the vehicle towing it.
Gross trailer weight of 1,401 kg (3,081 Ibs) to 2,800 kg (6,160 Ibs) – Brakes are required, including a breakaway brake.
Gross trailer weight of more than 2,800 kg (6,160 Ibs) – Brakes are required, and the trailer brakes must be capable of being applied by the driver independently of the towing vehicle's brakes. A surge brake does NOT meet this requirement. A breakaway brake is also required. Brakes are required on all axles.
The sole exemption to this rule is for a 3 axle house trailer, in which case brakes are only required on 2 of the 3 axles.
This could catch those with heavier toads. Do any of the toad braking systems allow independent application of brakes? Also catches me because my brake system is a surge brake.
ppine
Northern Nevada
Posted: 07/30/19 07:27am Link  |  Quote  |  Print  |  Notify Moderator
Roads in BC and Alberta are steeper than US roads. Their design criteria are less stringent. There are some long 12% grades. You need brakes that work or you are going to have problems.
SideHillSoup
South Eastern British Columbia
Posted: 07/30/19 03:27pm Link  |  Quote  |  Print  |  Notify Moderator
MDKMDK wrote:
Hey Soup, as long as you're not appearing regularly on Jamie Davis' TV show, you must be OK, eh? That Coquihalla Pass is one nasty piece of work. We did the one farther east between Radium HS and Banff along 93 back in 2015. It was a foothill compared to the ones near you, I bet. Keep the rubber on the road, and take care out there.
I’m about 6 hrs and 5 mountain passes east of the Coq.
The Coq isn’t all that bad, no worse than any other high mountain pass in BC. Yes they get snow, just like the mountain passes around me, but the difference is ... they have a TV Show... we don’t.
The problem with the Coq is that it is the main East/ West Hwy between Vancouver area and the rest of Canada, and NO BODY slows down no matter the weather.
I live 20 minutes from the Highest Mountain Pass open year round in Canada, that mountain pass is shutdown often during the winter for avalanche control. Everyone around here plan there winter trips so that you are cleaning the Summit by 06:30 as Avalanche control starts “ usually” at 7:00.
Avalanche Control
There are a lot of mountain passes and hills that are worse than the hill going down into Radium Hot Springs, it’s just traveled more often than the ones back here in the Bush... ( grin)
Soup.
2018 Northern Lite 8-11 EX Dry Bath
2017 Sierra SLE, 3500 HD / 4x4 / Duramax with a 6 speed Allison Trans
Torklift Super Hitch 20K, 48" Super Truss, front and rear frame mounted tie downs
Fast Gun Long Range SS Turnbuckles, Fast Gun locks
MDKMDK
Canada
Posted: 07/30/19 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
Avalanche Control
Soup.
OMG, that avalanche control vid tells me "avoid the Kootenay Pass, if possible, in avalanche season". Better they bring it down under control, than have it come down unexpectedly on some vehicles. You deal with that every year?
Mike.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
wilber1
Abbotsford B.C.
Posted: 08/12/19 11:23am Link  |  Quote  |  Print  |  Notify Moderator
cross21114 wrote:
BC Regulations
You would pretty much have to be towing a 3/4 T to be over 6000 lbs.
"Never trust a man who has not a single redeeming vice" WSC
2011 RAM 3500 SRW
2015 Grand Design Reflection 303RLS
Veebyes
Posted: 08/12/19 11:40am Link  |  Quote  |  Print  |  Notify Moderator
Yes they must be set to metric standards too. Who comes up with such nonsense. Right up there with how bad the northern roads supposedly are.
2007 Alpenlite 34RLR
stevemorris
ontario
Posted: 08/14/19 04:07am Link  |  Quote  |  Print  |  Notify Moderator
Ontario and quebec are pretty straight forward
any trailer over 2000 lbs must have brakes on ALL wheels and there must a functioning breakaway system
a car on a dolly IS considered a trailer and has the same requirements
2017 Ram 1500 4door, 4x4, 5.7 l hemi, 8 speed
2008 KZ Spree 260
JaxDad
Greater Toronto Area
Posted: 08/14/19 05:55am Link  |  Quote  |  Print  |  Notify Moderator
The threshold for brakes in Ontario is 3,000 pounds (1,360kg), not 2k.
Car dollies are not trailers and they do not require brakes in Ontario.
