RV.Net Open Roads Forum: Special Trailer Brakes Required in Canada?
Open Roads Forum  >  RVing in Canada and Alaska  >  Canada
 > Special Trailer Brakes Required in Canada?
allen8106
Burrton. KS
Posted: 07/29/19 04:40pm Link  |  Quote  |  Print  |  Notify Moderator
I had a friend tell me they had heard that there were some sort of special trailer brakes required in Canada.
Any info on this, truth or not?
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 20
Old-Biscuit
Verde Valley
Posted: 07/29/19 04:46pm Link  |  Quote  |  Print  |  Notify Moderator
YES........
They are required to work
Did you ask your 'friend' WHERE they heard this outlandish information?
allen8106
Burrton. KS
Posted: 07/29/19 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
Old-Biscuit wrote:
YES........
Honestly she said her husband told her who heard it from someone else. It kind of sounded like it was bad information and I've never read anything like that in all my Alaska/Canada research but you never know so thought I would ask.
MDKMDK
Canada
Posted: 07/29/19 04:57pm Link  |  Quote  |  Print  |  Notify Moderator
Here are some regs by province, but no brake regulations.
https://www.rvda.ca/ProvRVRegs.asp
This site also has some brake info.
https://www.rvda.ca/ProvBrakeReqts.asp
Caveat: Laws and regulations can change up here quickly.
If you are in doubt, check with the provincial ministry of transport for the province where you plan to tow, for specific up to date information.
Mike.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
pianotuna
Regina, SK, Canada
Posted: 07/29/19 05:25pm Link  |  Quote  |  Print  |  Notify Moderator
British Columbia has the most stringent trailer brake requirements.
Regards, Don
wilber1
Abbotsford B.C.
Posted: 07/29/19 06:03pm Link  |  Quote  |  Print  |  Notify Moderator
It's a provincial thing.
BC Regulations
Trailer Brake Requirements
Gross trailer weight of 1,400 kg (3,080 Ibs) or less – Brakes are required if the trailer and its load weigh more than 50% of the licensed weight of the vehicle towing it.
Gross trailer weight of 1,401 kg (3,081 Ibs) to 2,800 kg (6,160 Ibs) – Brakes are required, including a breakaway brake.
Gross trailer weight of more than 2,800 kg (6,160 Ibs) – Brakes are required, and the trailer brakes must be capable of being applied by the driver independently of the towing vehicle's brakes. A surge brake does NOT meet this requirement. A breakaway brake is also required. Brakes are required on all axles.
The sole exemption to this rule is for a 3 axle house trailer, in which case brakes are only required on 2 of the 3 axles.
"Never trust a man who has not a single redeeming vice" WSC
2011 RAM 3500 SRW
2015 Grand Design Reflection 303RLS
MDKMDK
Canada
Posted: 07/29/19 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
Probably because they have the greatest need, what with all those pesky mountains all over the place. [emoticon]
SideHillSoup
South Eastern British Columbia
Posted: 07/29/19 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
Yup... usually a couple times a year someone that’s NOT from the mountains of BC will end up picking rhubarb out of their teeth or worse.
I have two mountain passes on either side of my house..... those Pesky mountains are everywhere... [emoticon]
Just make sure your tow vehicle and trailer have good working breaks and you keep an eye on the roads signs, and you will be fine.
Have fun up here
Soup.
2018 Northern Lite 8-11 EX Dry Bath
2017 Sierra SLE, 3500 HD / 4x4 / Duramax with a 6 speed Allison Trans
Torklift Super Hitch 20K, 48" Super Truss, front and rear frame mounted tie downs
Fast Gun Long Range SS Turnbuckles, Fast Gun locks
MDKMDK
Canada
Posted: 07/29/19 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
Hey Soup, as long as you're not appearing regularly on Jamie Davis' TV show, you must be OK, eh? That Coquihalla Pass is one nasty piece of work. We did the one farther east between Radium HS and Banff along 93 back in 2015. It was a foothill compared to the ones near you, I bet. Keep the rubber on the road, and take care out there.
pyoung47
MO
Posted: 07/30/19 04:34am Link  |  Quote  |  Print  |  Notify Moderator
In Canada, brakes must be able to be operated in either French or English.
