RV.Net Open Roads Forum: Special Trailer Brakes Required in Canada?
Open Roads Forum  >  RVing in Canada and Alaska  >  Canada
 > Special Trailer Brakes Required in Canada?
StirCrazy
Kamloops, BC, Canada
Posted: 08/14/19 06:56pm Link  |  Quote  |  Print  |  Notify Moderator
SideHillSoup wrote:
MDKMDK wrote:
Hey Soup, as long as you're not appearing regularly on Jamie Davis' TV show, you must be OK, eh? That Coquihalla Pass is one nasty piece of work. We did the one farther east between Radium HS and Banff along 93 back in 2015. It was a foothill compared to the ones near you, I bet. Keep the rubber on the road, and take care out there.
I’m about 6 hrs and 5 mountain passes east of the Coq.
The Coq isn’t all that bad, no worse than any other high mountain pass in BC. Yes they get snow, just like the mountain passes around me, but the difference is ... they have a TV Show... we don’t.
The problem with the Coq is that it is the main East/ West Hwy between Vancouver area and the rest of Canada, and NO BODY slows down no matter the weather.
I live 20 minutes from the Highest Mountain Pass open year round in Canada, that mountain pass is shutdown often during the winter for avalanche control. Everyone around here plan there winter trips so that you are cleaning the Summit by 06:30 as Avalanche control starts “ usually” at 7:00.
Avalanche Control
There are a lot of mountain passes and hills that are worse than the hill going down into Radium Hot Springs, it’s just traveled more often than the ones back here in the Bush... ( grin)
Soup.
I don't know, I have traveled every rout several times, I think the biggest thing with the Coq is a combination of the steepness and length of it compared to others, also the elevation. you are going up at and average of 7% for quite a distance with two spots on smasher hitting 13%. yes coming into golden is pretty steep but not anywhere close to the lengths, same as the stich backs around Creston and any other place I can remember. add this to the fact that most people don't slow down like you said, it really works the vehicles.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
SideHillSoup
South Eastern British Columbia
Posted: 08/14/19 08:51pm Link  |  Quote  |  Print  |  Notify Moderator
Avalanche Control
Soup.
Steve
Well Steve I’m not sure where you found switch backs around Creston unless you were on some logging road near Creston, and I can’t figure out where the steep hill is that comes into Golden, so I will stick with my statement that the Coqu is no worse than any other high elevation mountain in B.C. and the amount of traffic and speed are the main influences on that section of Hwy.
Soup.
2018 Northern Lite 8-11 EX Dry Bath
2017 Sierra SLE, 3500 HD / 4x4 / Duramax with a 6 speed Allison Trans
Torklift Super Hitch 20K, 48" Super Truss, front and rear frame mounted tie downs
Fast Gun Long Range SS Turnbuckles, Fast Gun locks
