RV.Net Open Roads Forum: Travel Trailers: Problems with Schwintek In-Wall Slide-Out
 > Problems with Schwintek In-Wall Slide-Out
gerpeters
Home
Posted: 07/29/19 06:14pm Link  |  Quote  |  Print  |  Notify Moderator
I bought a 2017 Wildwood RV (Forest River) earlier this year. Slide-out was working fine for a few camping trips.
This is the first time I have own a travel trailer with the Schwintek In-Wall Slide-Out
When I start the slide-out I hear the motors starting and both sides start evenly. At about 5-10 inches out on one side motors stop and then the slide goes out uneven. I do of course stop at that point and slide back in. If I go back and forth for a few times it works to slide out the slide-out. The same issue when I slide the slide-out back in. Both sides start and then one side stops
Any idea how to troubleshoot the issue?
shastagary
minnesota
Posted: 07/29/19 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
this may fix it watch the video Schwintek In-Wall Slide-Out System - Retiming
azdryheat
Tucson, AZ
Posted: 07/29/19 08:04pm Link  |  Quote  |  Print  |  Notify Moderator
Are you hooked up to shore power? My slides don't work as well when only under battery power.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2011 Harley Ultra Limited
2016 RZR 900
PaulJ2
Northwest Oregon
Posted: 07/29/19 10:26pm Link  |  Quote  |  Print  |  Notify Moderator
To keep this from happening again----be sure and hold the switch on for a few seconds after it is fully retracted or extended.
gerpeters
Home
Posted: 07/30/19 06:11am Link  |  Quote  |  Print  |  Notify Moderator
Thank you! That sounds like will fix my problem
gerpeters
Home
Posted: 07/30/19 07:24am Link  |  Quote  |  Print  |  Notify Moderator
I have tried it both ways. Does not seem to make a difference
ependydad
Here and there
Posted: 07/30/19 07:49am Link  |  Quote  |  Print  |  Notify Moderator
Sad to say, my past experience is that this problem got worse and worse until the slide stopped operating. The only method of manual retraction is to pull the motors and push like hell.
At that point, a repair shop needs to get a new slide out rack from Lippert and install it. Lippert builds them on demand and it takes about 3 weeks to get. Cost + installation ran $1,400-1,800.
And I did the motor synchronization every time.
2017 Spartan 1245 by Prime Time
2018 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: TrailerSaver TS3
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
fdwt994
Indianapolis, IN
Posted: 07/30/19 10:14am Link  |  Quote  |  Print  |  Notify Moderator
Same here. Both our slides were Schwintek. One was rebuilt under warranty when the unit was less than two years old (had the one year extended warranty) and the other, larger living room slide failed a couple of weeks ago at the campground. Unfortunately for us, we were unable to push hard enough even after disengaging the motors. Have now traded the unit in for one without Schwintek based on our experience and all the research I did about them. My advice- get it to the shop before the same thing happens to you. Good luck!
2018 F250 6.2 Crew Cab
2018 Salem Hemisphere GLX 312QBUD
A family who loves to camp!
nickthehunter
Southgate, MI
Posted: 07/30/19 01:51pm Link  |  Quote  |  Print  |  Notify Moderator
This !!~!!! Make sure you hold the button after the wall stops moving for at least 3 seconds. This keeps the motors in time.
One other thing, make sure there isn't something restricting the slide from moving properly. Something as little as a piece of splintered wood could make the motor one one side over torque and stop.
gerpeters
Home
Posted: 07/30/19 06:01pm Link  |  Quote  |  Print  |  Notify Moderator
So is the Schwintek In-Wall Slide-Out good quality? Based on a few responses it sounds like a poor choice for an RV that comes with the Schwintek.
