RV.Net Open Roads Forum: Tech Issues: Fantastic Fan Motor???
 > Fantastic Fan Motor???
joelyn
Az
Posted: 07/29/19 06:36pm Link  |  Quote  |  Print  |  Notify Moderator
Have a fantastic fan in bathroom, should be from 2004 when the trailer was built.. My motor stopped working about 6 weeks ago. The lift motor was a 17 RPM motor. I called dometic and they sent me another motor but it was a 7RPM motor, same everything just the RPMS different..
Called them and they sent me another replacement one (supposedly the right one) and just got it and AGAIN its the 7RPM motor.
QUESTION, will the 7 RPM lift motor work and is there much of a difference between a 7 and 17 RPM to lift the dome?? will it just take longer or faster???
asked tech support at dometic and they could not give me a answer.
Thanks again for any suggestions.
* This post was edited 07/29/19 06:42pm by joelyn *
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 07/29/19 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
Slower motor slower operation. MIGHT have more lifting power. You'll be the first to know [emoticon]
STBRetired
I-80 and I-55
Posted: 07/29/19 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
Here on Amazon is the 17 RPM motor. Either one will work, but I recall reading somewhere that the wiring colors are reversed. Amazon has both the 7 RPM and 17 RPM motors. Just search for "fantastic fan lift motor"
1999 Newmar MACA 3796 F53 6.8L
2016 Ford Edge Sport
Roadmaster Sterling A/T with Brake Buddy Select
old guy
Oregon (pronounced Or e gun)
Posted: 07/29/19 08:51pm Link  |  Quote  |  Print  |  Notify Moderator
well if it were me I would call them one more time and ask for two things. the right motor this time and a return shipping label to sent the wrong ones back
