RV.Net Open Roads Forum: Class A Motorhomes: Replacement Fridge or New Cooling Unit
 > Replacement Fridge or New Cooling Unit
Page of 5
SGTJOE
Utah
Posted: 07/30/19 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2001 National Tradewinds and my dometic fridge has just had it's 2nd cooling unit quit. 6 Years ago I paid $1200.00 to have it changed out, now I'm being told that it will cost me a little over $3,000.00. So my question to you all is do I do it or do I have a residential fridge installed instead.
Now if I do a residential fridge has anyone on here done that and what was the cost? My fridge is a Dometic NDR 1292, it's a side-by-side. For those who have switched over, can you tell me the cost and where a good place that has the experience to get it done. I live in Southern Utah.
2001 Trade Winds 7390
Toad 03 Grand Am
Big Katuna
Deland, FL
Posted: 07/30/19 03:11pm Link  |  Quote  |  Print  |  Notify Moderator
I replaced my Norcolds cooling unit a few years back and would go that route again.
Amish made unit works better than OEM
They have a compressor based version now.
Mine is a four door and a window would have to be removed which I was loathe to do.
My Kharma ran over my Dogma.
allbrandauto
maryland
Posted: 07/30/19 03:13pm Link  |  Quote  |  Print  |  Notify Moderator
we used a Samsung rf18 fridge size about the same as yours fit thru my door. installed my self not hard bought a inverter to. works great spent about 1500 for everything.if your going to have someone install it add another 1000-1500 to do it.best thing I ever did to my motorhome
grumpy3b
California
Posted: 07/30/19 03:30pm Link  |  Quote  |  Print  |  Notify Moderator
still nursing mine along. Once the solar and batteries are upgraded I'm going with anything that has a high efficiency compressor. Will have over 5kWh battery power so one of the new high efficiency options won't really cost anything to run. I'm out west so sun is rarely an issue for more than a day or two likely enough battery power to cover around 4-6 days of marginal or no sun w/o needing the generator.
If i can fit a residential into the kitchen I will otherwise I'll go with the Amish high efficiency compressor upgrades. Watched a video and as long as you can, DIY retrofit is nit too fiddly.
midnightsadie
ohio
Posted: 07/30/19 03:36pm Link  |  Quote  |  Print  |  Notify Moderator
theres a couple places in Indiana that rebuild units MUCH CHEAPER than 3k.but I can,t find there number, somebody will chime in with the info.
Branson N Tucson
Tn
Posted: 07/30/19 04:22pm Link  |  Quote  |  Print  |  Notify Moderator
I replaced my Norcold a year ago. I have a 2003 Fleetwood Providence. I got a residential Samsung 2 door, 2 draw freezer at Lowe's for $800.00.
It had a scratch on the side. Lucky the Unit fit thru my side window with no problem. It also fit were the Norfolk was. Had to loose a small draw. Had it put in when in Yuma. They charge me $890.00 to install.
DW loves it, and I love my ice cream.
pianotuna
Regina, SK, Canada
Posted: 07/30/19 05:01pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
I believe Dometic makes a compressor cooling unit now for retrofitting. That is likely what I'll do when the day comes.
Regards, Don
ScottG
Bothell Wa.
Posted: 07/30/19 05:06pm Link  |  Quote  |  Print  |  Notify Moderator
My new Norcold is an absolute pile of junk and I'll probably be installing an Amish cooling unit or a compressor conversion kit from JC Cooling in it eventually.
If your going to stay with an absorbtion type fridge, you'd be much better off getting a good cooling unit for your existing fridge rather than a whole new fridge.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
kmb1966
Lake Charles
Posted: 07/30/19 07:13pm Link  |  Quote  |  Print  |  Notify Moderator
I too have the new Amish Cooling unit in my Norcold. BUT GUESS WHAT? IT DOESN'T COOL REASONABLE EITHER! JC Refrigeration blames the installer, and the installer blames JC Refrigeration and you get no where with either. Right now my unit is ON with the new Amish cooling unit, and it is 10 degrees in the freezer and 42 in the refrigerator. Ice cream does NOT get frozen hard, and if you open the door twice, it's now 45 degrees in the refrigerator and takes many hours to get to 42. AND 42 IS NOT THAT SAFE!
My plan is to get a residential unit and spend the $ and call it DONE. I am tired of playing the Norcold Amish games while they take my money and make up reasons to blame each other.
SGTJOE
Utah
Posted: 07/30/19 07:36pm Link  |  Quote  |  Print  |  Notify Moderator
Okay folks, for those of you who went residential how did you restrain the fridge from falling out as you go down the road.
Page of 5
