RV.Net Open Roads Forum: Class A Motorhomes: Toilet replacement
 > Toilet replacement
two travelers
Smithtown, NY
Posted: 07/30/19 03:37pm Link  |  Quote  |  Print  |  Notify Moderator
We have had issues with our thetford toilet over the last year. First, the pedal mechanism broke. When it was replaced, the seal was also replaced. Well the seal did not hold water despite letting the pedal slam back. Figured a bad seal and repalced and still have the same problem. Perhaps it's time for a new toilet. Any recommedations on the best one? Don't need a porcelin bowl for the RV.
ferndaleflyer
everywhere
Posted: 07/30/19 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
I might not be much help since I replaced mine with a porcelin one. It was pretty simple and took about an hour at most to install. Mine was a Dometic. It had been sitting a month and I checked it today and it still had water in it.
enblethen
Moses Lake, WA
Posted: 07/30/19 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
I changed out our throne to an Thetford Bravura. It has a larger base which makes it more stable.
The unit is set up to fit most bolt patterns without modification.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Ed_Gee
Central Oregon coast
Posted: 07/30/19 08:48pm Link  |  Quote  |  Print  |  Notify Moderator
You're really shorting yourself by not considering the Dometic toilets, 310, 320 models. .....porcelain models or not.....
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
cavie
Posted: 07/31/19 02:24pm Link  |  Quote  |  Print  |  Notify Moderator
Go with the 320 porcelain. 310's have very hard to change ball seal. I have the t-shirt.
cavie
Posted: 07/31/19 02:25pm Link  |  Quote  |  Print  |  Notify Moderator
