RV.Net Open Roads Forum: Class A Motorhomes: F53 Chassis Lean
 > F53 Chassis Lean
crawford
Dandridge Tenn.
Posted: 07/31/19 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
I went through this with Ford before they told me the coach builder did it not them. Went they got the chassis they knew what specs were if they went out side of them they needed to correct the problem.
Change from a c class to a A class Georgetown 07 triple slide
DFord
Near St Louis, MO
Posted: 07/31/19 09:40pm Link  |  Quote  |  Print  |  Notify Moderator
Have you made any measurements yourself? Is it the chassis leaning or the box sitting on the frame? That would pretty much point the finger at the responsible party. Another question for you, why would you take delivery of it in the first place if it was leaning so badly the steps jammed into the ground? Is this something that started after you bought it or was it that bad to start with?
Don Ford
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
blknomad
ferrum va
Posted: 08/01/19 06:13am Link  |  Quote  |  Print  |  Notify Moderator
Take it to a truck spring shop and let them put a spacer in and be done with it.
crawford
Dandridge Tenn.
Posted: 08/01/19 09:17am Link  |  Quote  |  Print  |  Notify Moderator
Spring shop may add a extra leaf spring I don't think a good shop would add any kind of spacer'
Gjac
Milford, CT
Posted: 08/01/19 09:46am Link  |  Quote  |  Print  |  Notify Moderator
I would check the ride height front to back and side to side that will tell you if there is something wrong with the chassis suspension. Just measure the distance from the top of the rubber bumper to the frame. Make sure the ground is perfectly level like in a Walmart parking lot your driveway may be pitched like mine to allow rain to run off. If your ride height looks good, then measure the bottom of the door panels front to back and side to side. This will tell you where your problem is. What were your 4 corner weights? Were they higher on the curb side? Let us know what you find and you will get better help.
Pirate
Northeast Tennessee
Posted: 08/01/19 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
It is a very common fix. The shop that put in my spacers to fix a lean said they do it all the time. Reputable large truck place. Had mine done several years ago, very pleased to this date. No need to add a spring.
dougrainer
Carrolton, Texas
Posted: 08/01/19 04:13pm Link  |  Quote  |  Print  |  Notify Moderator
Spacers on Ford Chassis are a common fix. But, the fix is on the Coach builder. Tiffin sends out the spacers to the Spring shop on their Ford Chassis. You need to escalate at Jayco Motorized to get them on board. They will fix the problem once all the correct procedures have been followed. The RV DEALER is a must to be involved in the fix. Doug
crawford
Dandridge Tenn.
Posted: 08/02/19 10:05am Link  |  Quote  |  Print  |  Notify Moderator
Just got back from a specially spring shop Quote no good shop would in spaces because they cause weak spots after a while.... They would put in heaver coils and add extra leafs to match the front so not to affect the steering much and alignment could be done properly. He went into a lot with me but to scientific for me but that was in general and I believe him being in the trade for 40 plus year and 2 generation.
dougrainer
Carrolton, Texas
Posted: 08/02/19 10:28am Link  |  Quote  |  Print  |  Notify Moderator
Spacers are done all the time in the RV Class A Ford chassis. What he wants to do is OK, IF YOU WANT TO SPEND THE MONEY. But, it is not needed. Doug
crawford
Dandridge Tenn.
Posted: 08/08/19 11:31am Link  |  Quote  |  Print  |  Notify Moderator
Again spacers are ok for doing alignment. I seen that but for taken a heavy side to be level I still can't be leave it . Sorry worked in a tool room 35 years with all types of steel we went through training and you needed to shim something it woulds be the whole piece or nothing. Just because a company does it a cheep way does it make it right ??
 > F53 Chassis Lean
