RV.Net Open Roads Forum: Travel Trailers: Battery Charger Replacement Help!
 > Battery Charger Replacement Help!
Thoodenpyl
WA
Posted: 08/01/19 10:12am Link  |  Quote  |  Print  |  Notify Moderator
I have a custom Nugget made in 1975. The battery charger has gone and I need to replace it but the system is custom. I think it is pretty straight forward but I would love some idea if I am right.
The new chargers have several phases, can I adapt the battery plug in to this plug in again? If so do I have to turn the charger switch on and off if the new battery chargers have trickle mode?
I can”t get my pictures to show up, so explaining this seems difficult [emoticon]
* This post was edited 08/01/19 10:21am by Thoodenpyl *
enblethen
Moses Lake, WA
Posted: 08/01/19 10:24am Link  |  Quote  |  Print  |  Notify Moderator
can you get the model number of your "converter" and post it?
Most converters have different charge rates depending on battery requirements and do have a trickle charge rate.
* This post was edited 08/01/19 10:36am by enblethen *
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
opnspaces
San Diego Ca
Posted: 08/01/19 11:01am Link  |  Quote  |  Print  |  Notify Moderator
It looks like you have a knife switch that you flip to select either the right or left side battery. What is the purpose for the switch? Is it to use only one battery at a time and keep the second in reserve? Or was there a limitation with your original charger and you could only charge one battery at a time.
Here's your pictures. I think Apple is preventing direct linking from websites so i copied them into the RV.net hosting site.
[image]Click For Full-Size Image.
* This post was edited 08/01/19 11:11am by opnspaces *
1996 Suburban 4x4. 350, 4.10 3/4 ton
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
Thoodenpyl
WA
Posted: 08/01/19 11:12am Link  |  Quote  |  Print  |  Notify Moderator
Not sure why the knife switch is there. The charger is VERY old so assuming it could only charge one at a time. I never have two batteries. I mostly use electric but to complete the circuit I need to have a charger.
Thoodenpyl
WA
Posted: 08/01/19 11:14am Link  |  Quote  |  Print  |  Notify Moderator
I’m just wondering if I can use a new charger, adapt the battery connection to the plug in connection and call it good?
opnspaces
San Diego Ca
Posted: 08/01/19 11:40am Link  |  Quote  |  Print  |  Notify Moderator
Very possible, but can you you give us a bit more information to help give an informed opinion.
Is there a fuse box of any sort in the trailer?
Is the charger and fuse box one assembled unit or are they separate?
Does your trailer have electric brakes and you have a brake controller in the tow vehicle? Or does the trailer use a flat 4 wire plug to connect to the tow vehicle? I'm asking only because the battery has to be present and connected for the breakaway system (if equipped) to work when towing.
Can you post a picture of the front of the converter or fuse panel if equipped? You can try using the photo and hosting page for that. When using the link make sure you click on the "full size photo" checkbox and copy the entire address into your post. If you still can't get the photos to post then just post them like you did before and I or somebody else on here will move them for you. Photo posting link.
Here's a link to BestConverter.com. You might try clicking on the "Ask Randy" link at the top of the page and talk to him. He's supposed to be very knowledgeable about the systems. But my guess is he'll need some kind of model number off the converter panel.
Link
* This post was last edited 08/01/19 03:13pm by opnspaces *   View edit history
Thoodenpyl
WA
Posted: 08/01/19 12:09pm Link  |  Quote  |  Print  |  Notify Moderator
***Link Removed***
[image]***Link Removed***.
Thoodenpyl
WA
Posted: 08/01/19 12:10pm Link  |  Quote  |  Print  |  Notify Moderator
There isn’t a converter. This is a custom job with a battery charger.
Thoodenpyl
WA
Posted: 08/01/19 12:12pm Link  |  Quote  |  Print  |  Notify Moderator
Thoodenpyl
WA
Posted: 08/01/19 12:15pm Link  |  Quote  |  Print  |  Notify Moderator
