RV.Net Open Roads Forum: Travel Trailers: Battery Charger Replacement Help!
 > Battery Charger Replacement Help!
time2roll
Posted: 08/01/19 12:18pm Link  |  Quote  |  Print  |  Notify Moderator
Get a modern deck mount converter and wire it direct to the battery or 12v system and let it run 24/7 when power is available.
http://www.bestconverter.com/PD-9245C-45-Amp-RV-ConverterCharger
675w Solar pictures back up
Thoodenpyl
WA
Posted: 08/01/19 12:36pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you! That is what I was thinking too.
opnspaces
San Diego Ca
Posted: 08/01/19 12:57pm Link  |  Quote  |  Print  |  Notify Moderator
[image]Click For Full-Size Image.
1996 Suburban 4x4. 350, 4.10 3/4 ton
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
time2roll
Posted: 08/01/19 01:15pm Link  |  Quote  |  Print  |  Notify Moderator
Or you could go crazy and install a modern power distribution center. This would have all the 120v breakers and stack of 12v fuses all in one place. Depending on location of the main connections this might require pulling some wire to the central location.
http://www.bestconverter.com/PD4045-45-Amp-Inteli-Power-Mighty-Mini-Power-Center
opnspaces
San Diego Ca
Posted: 08/01/19 01:16pm Link  |  Quote  |  Print  |  Notify Moderator
I edited my original post as I am not an expert; You should not follow any of my suggestions except to contact a licensed electrician and maybe call Randy at Bestconverters and get his advice.
Good luck getting your charging system back up and running. Hopefully you will have your system back up and running while camping season is still here.
* This post was last edited 08/01/19 03:32pm by opnspaces *   View edit history
Thoodenpyl
WA
Posted: 08/01/19 01:58pm Link  |  Quote  |  Print  |  Notify Moderator
I just want to stay very basic. This is only a 9’ trailer with two plug ins a microwave refridge and fantastic fan.
ScottG
Bothell Wa.
Posted: 08/01/19 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
Sell the old charger on eBay, working or not - or I'll take it if you don't want to bother!
People collect stuff like that for garage art.
BTW, it would be better if the new charger was not mounted in the same compartment as the battery.
Good luck!
Scott
* This post was edited 08/01/19 04:43pm by ScottG *
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
Gjac
Milford, CT
Posted: 08/14/19 09:22am Link  |  Quote  |  Print  |  Notify Moderator
If you want to stay very basic, and you don't have a converter now, and you use hookups when camping, I would just install a cheap 10 to 20 amp automotive charger in its place. From your posts the refrigerator, micro wave, fan etc all run off of 120v the only thing you use 12v for is the lights is that correct?
