RV.Net Open Roads Forum: Fifth-Wheels: Fifth-Wheel Longevity?
 > Fifth-Wheel Longevity?
larry barnhart
wenatchee. wa usa
Posted: 08/01/19 04:44pm Link  |  Quote  |  Print  |  Notify Moderator
not a brand picture but looks the same chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
valhalla360
No paticular place.
Posted: 08/01/19 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
They can be kept going pretty much forever...but eventually it's cheaper to replace than to repair.
We replaced 20yr old trailer last year as it was time to redo the roof and for a little more, we could get a 10yr old model. Other than the roof (no rot just the rubber surface starting to fail), everything worked fine and was in good condition.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
larry barnhart
wenatchee. wa usa
Posted: 08/01/19 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
We feel our air hitch and air on the fifth suspension helps for longer life of the alpenlite.
chevman
Lantley
Ellicott City, Maryland
Posted: 08/01/19 08:03pm Link  |  Quote  |  Print  |  Notify Moderator
Dutchmensport wrote:
In other words, you REALLY need to own the camper a good year before hitting the road permanently for all these reasons. That year will flush out defect issues. It will give you a year to really know your rig, it's limitations, it's strengths and weaknesses. By aggressively traveling over that year and having a home to come back to, will provide a place to do those fixes and changes to make your rig more comfortable and road-worthy for longevity.
Over that first year, you'll learn a lot, especially if you camp as much as you can and make an effort to "experiment" with all kinds of camping styles: State, Federal, National Parks, Private campgrounds, boondock, WalMart overnighting style, full hook-up sites, and minimum hook-up sites
Very Good advice above, Not sure I have ever heard it put quite that way.
But his Dutchman's advice is accurate and based on experience.
It applies to many RV camping topics and is the key to successful RV'ing.
2019 Duramax w/hips,2012 Open Range,Titan Disc Brake
H-head TPMS,BD3,RV safepower,17" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps
Correct Trax,Splendide
one_strange_texan
New Caney, TX (when not on the road)
Posted: 08/01/19 08:56pm Link  |  Quote  |  Print  |  Notify Moderator
Having owned two fifth wheels now and also full timing for the last 18 months, I would say the rule of thumb is 10 years, but there are so many variables you cannot boil it down to a single number. How much maintenance you are willing to do yourself or pay for, aesthetics, new features being offered on the newer models, rough use, workmanship of the manufacture, etc., etc.
one_strange_texan
2015 Montana 3402RL
2015 Ram Diesel 3500 4WD single axle
ComanDanteRV
Atlanta
Posted: 08/01/19 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you everyone for the great reponses and advice. So consensus seems to be that a 10-15 year time frame, with good maintenance, is a reasonable assumption.
This will help with our long term financial planning so thank you all.
We do have some experience with dozens of 2-3 week trips and a couple of 8 week trips as well. We rented a variety of RVs to see what woudl work for us.
Great advice on a one year break-in period too. We will definitely plan on that.
Super_Dave
Harrisville, UT
Posted: 08/02/19 07:57am Link  |  Quote  |  Print  |  Notify Moderator
I would imagine that full timing in limited locations versus constant travel would be a huge variable. We use our 5th wheel as a cabin with very limited miles per year.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 2003 Jetcraft 2125 - Yamaha 150 HP & 8 HP Kicker
Veebyes
Posted: 08/03/19 08:20am Link  |  Quote  |  Print  |  Notify Moderator
Lots of variables starting with the unit itself. Generally you gets what you pays for. New is not necessarily the way to go either. Better buy a newish upper end builder than a new mid market for same money.
We have a now 12 year old Alpenlite. It now has an estimated 150,000 miles & 1800 nights spent in it. It has required the services of professionals only 3 times. A rebuild of spring hanger areas to upgrade them. Installation of a fridge. A full brake service. All other repairs & maintenance, & we have had our share, done by owner. Very important.
It enjoys 7 months of indoor storage & a good cleaning followed by 2 days worth of waxing a year. It looks very good for its age.
There is no 'itch' to sell & get something else. At this rate it should be good for another 10 years at this level of care.
2007 Alpenlite 34RLR
larry barnhart
wenatchee. wa usa
Posted: 08/03/19 10:43pm Link  |  Quote  |  Print  |  Notify Moderator
3273 nights for us on our 2001 and a rebuild of a spring hanger next month.
chevman
