RV.Net Open Roads Forum: Class A Motorhomes: Radiator Over Flow Tank
 > Radiator Over Flow Tank
want-a-be
On the road
Posted: 08/01/19 11:15am Link  |  Quote  |  Print  |  Notify Moderator
Has anyone replaced their radiator over flow tank on a Cummins Diesel? If so did you have to go to a dealer for a replacement? What was the cost! It's on a Freightliner chassis.
* This post was edited 08/01/19 11:39am by want-a-be *
bdpreece
Yuma Arizona / Oregon Traveler
Posted: 08/01/19 11:35am Link  |  Quote  |  Print  |  Notify Moderator
I had mine replaced by Freightliner. They used a metal truck over flow tank and fabricated a bracket system to hang it. Unfortunately I no longer have a visual of how much fluid is in the tank so every once in awhile I have to use a dip stick to check it.
Brian, Loretta & Daisy (Golden Retriever)
2008 Holiday Rambler Endeavor PDQ40
2014 Ford Explorer toad
Branson N Tucson
Posted: 08/02/19 05:07am Link  |  Quote  |  Print  |  Notify Moderator
Some one stated they had problems with the plastic ones, leaking at the seam. They have improved the newer ones. I had my leak at the seam.Freightliner replaced mine. Had to go thru the bedroom. Can't remember the cost.
donkeydew
OR
Posted: 08/03/19 07:27pm Link  |  Quote  |  Print  |  Notify Moderator
amazon part # 603-5201 will get you on the right place. hope this helps
MrWizard
Traveling
Posted: 08/03/19 10:32pm Link  |  Quote  |  Print  |  Notify Moderator
when the second plastic one on the safari started showing 'age' at only (2) years after install
i found a powered coated steel one online thru a link on a Monaco Forum
that was in 2014 IIRC it $149
it did come with a site glass, although i had to move it to a spare 'hole' facing outside what was the rear of coach
Radiate The Happy
1997 F53 Bounder 36s
