RV.Net Open Roads Forum: Fifth-Wheels: Hitch choice
 > Hitch choice
Page of 11
bobbyg123
Duvall, WA
Posted: 08/01/19 09:48pm Link  |  Quote  |  Print  |  Notify Moderator
Hi everyone. I own a 2017 F350 6.2L long bed crew cab, and I’m in the market for my first 5th wheel hitch after 10+ years of bumper pulling.
I’ve heard good things about B&W, but they of course make several different hitch options. What should I be looking for? My new 5th wheel won’t weigh more than 11,000 lbs loaded, and I won’t ever bigger than the set up I just purchased; certainly not with my gas truck.
Thanks.
2018 Jayco Eagle HT 29.5BHDS
2017 Ford F-350 CC 6.2L
Artum Snowbird
Campbell River, B.C., Canada
Posted: 08/01/19 10:00pm Link  |  Quote  |  Print  |  Notify Moderator
While I had the Patriot, everyone needs to know what you intend to do with it. If you want a hitch that will sit in your truck until you need it, it works great. If you want to have a clean box, you need to look further. If you want to remove it easily by yourself look farther too. I loved my B&W Patriot, but it got pretty heavy, even taking apart the two sections. Sometimes I had to rig up a hoist to get it in or out. Now I go for comfort driving, and parking and we have a Class C.
Mike and Carole
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers,
Triple E Motorhome and Fifth Wheel
bobbyg123
Duvall, WA
Posted: 08/01/19 11:18pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the reply. It’s going to be pretty permanent, as my truck is a dedicated tow vehicle. With that said, I hate the thought of not being able to remove it should I need the whole bed for hauling.
Ugh...
MFL
Midwest
Posted: 08/02/19 05:06am Link  |  Quote  |  Print  |  Notify Moderator
The 3300 B&W for oem puck system would be the best choice, if you have the puck system. You have the option of installing the under bed puck system if you don't have it now.
If you are going to use rails in the bed, then the Patriot is a great choice.
Jerry
austinjenna
Columbus, Ohio
Posted: 08/02/19 05:37am Link  |  Quote  |  Print  |  Notify Moderator
For me I went with an air ride hitch by Trailersaver the BD3 model. I don't think I would ever go back to a solid hitch after owning this one for a while. Previously I had a Reese which worked fine but then upgraded later on and dont regret it.
2010 F350 CC Lariat 4x4 Short Bed
2011 Crusader 298BDS 5th Wheel
Reese 16K
DutchmenSport
Indiana
Posted: 08/02/19 07:05am Link  |  Quote  |  Print  |  Notify Moderator
Good article: Click here. Read, enjoy, and be overwhelmed! But this covers a lot of information. Good luck in your choice.
ependydad
Here and there
Posted: 08/02/19 08:05am Link  |  Quote  |  Print  |  Notify Moderator
I can't recommend the B&W hitches any higher. They're the best fixed hitch on the market.
https://learntorv.com/bw-fifth-wheel-hitches/
The fact that it comes out in 2 pieces makes it manageable by 1 person. I used a furniture dolly to move it around the driveway and garage.
I had an Andersen Ultimate Fifth Wheel Connection and the ride, with our truck and trailer combination, beat my wife's back up. I did a head-to-head comparison between it and the B&W. I was gentle in the article, but for me- it's B&W or bust between the two:
https://learntorv.com/the-hitch-showdown/
And lastly, due to the pain caused by the Andersen and that the B&W I had wasn't rated for the trailer that I bought, I ended up switching to the TrailerSaver TS3. It's a full air ride hitch and is as nice as can be. We've had to learn that if our last movement direction is forward that we have to back the pin off of the hitch a bit, otherwise it binds up and makes the handle hard to release. But, it's a heavy bugger at 300 lbs. I've never lifted it and just hang it from the kingpin of the camper. When it's time to re-install it, I just back the truck under it and lower it onto the rails (with my wife's help).
2017 Spartan 1245 by Prime Time
2018 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: TrailerSaver TS3
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
pcm1959
home
Posted: 08/02/19 08:06am Link  |  Quote  |  Print  |  Notify Moderator
X2
I have a BD3 and would NEVER pull a fifth wheel without an air hitch. There are so many reports from owners having broken pin boxes anything you can do to help cushion the rigid connection between truck and trailer can't hurt.
If you rig is lighter you could also consider the less expensive BD1.
http://www.trailersaver.com/air-ride-suspension-hitches/
2018 GMC Sierra 3500 DRW 4x4 Duramax/Allison
2014 Lifestyle LS36FW
St Augustine, FL
Cummins12V98
on the road
Posted: 08/02/19 09:03am Link  |  Quote  |  Print  |  Notify Moderator
You can thank me later.
I tow this beast at 33k combined and 35k when double towing. I don't have an air hitch. I have an air bag pin box. Really don't see the ride getting any better. FACT is your trucks suspension has more to do with ride than anything else!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
bobbyg123
Duvall, WA
Posted: 08/02/19 11:50am Link  |  Quote  |  Print  |  Notify Moderator
snip...
Thanks. I suspect the Companion 3500 will be more than enough for my 10,500lb 5th wheel, no?
* This post was last edited 08/02/19 06:21pm by an administrator/moderator *   View edit history
Page of 11
 > Hitch choice
