RV.Net Open Roads Forum: Fifth-Wheels: Hitch choice
 > Hitch choice
Page of 11
Cummins12V98
on the road
Posted: 08/14/19 08:59am Link  |  Quote  |  Print  |  Notify Moderator
I agree a new B&W user should methodically go by their instructions for sure! When comfortable operating it THEN one can consider the VISUAL test.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
MFL
Midwest
Posted: 08/14/19 09:13am Link  |  Quote  |  Print  |  Notify Moderator
I don't tell anyone not to do a tug/pull test, no matter the hitch brand. I did the first few times, with my B&W. After further studying the hitch mechanism, it became obvious, due to design, with proper hookup, handle closed, pin inserted, it could not release the pin from the closed jaws. I also use the double look test. When backed in, handle closed/pinned, I look closely at jaws around pin. After finished raising landing gear, removing chocks, walk around rig, one more close look at jaws/pin, just before climbing in the truck. IMO, ALWAYS...doing the second look, can save a drop, due to a possible early on distraction.
Jerry
handsome51
Baytown
Posted: 08/15/19 11:26am Link  |  Quote  |  Print  |  Notify Moderator
bobbyg123 wrote:
Hi everyone. I own a 2017 F350 6.2L long bed crew cab, and I’m in the market for my first 5th wheel hitch after 10+ years of bumper pulling.
I’ve heard good things about B&W, but they of course make several different hitch options. What should I be looking for? My new 5th wheel won’t weigh more than 11,000 lbs loaded, and I won’t ever bigger than the set up I just purchased; certainly not with my gas truck.
Thanks.
You said long bed so I have to assume you have a real truck with a 8ft bed. That is what I call a long bed. Go ahead and do it right the first time and be happy. That is what I did in 2006 when I bought my first 5th wheel. Spend the money and buy either a 25k air safe hitch(25k because it has the Binkley Holland head on it) or a Trailersaver air hitch with a Binkley Holland head.You won't even know the 5th wheel is behind you. And nothing moves in the 5th wheel unless you slam on the brakes. Like my friend told me that said to buy the 25k air safe hitch. He said " I am not telling you it is worth the money, but I like the ride". He pulled a center console boat behind his 5th wheel to the lake. And said one time he forgot and left a soap bottle on the kitchen counter. And when he go back home from the lake it was still sitting their.
pcm1959
home
Posted: 08/15/19 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks.
I agree 100%.
I'm amused how often B&W hitch owners rave about their hitches. I'm by no means discounting their quality, the design or anything else about B&W. However, there is no comparison between a fixed hitch and a floating hitch like those mentioned above regardless of brand.
I'd never tow a fifth wheel again after having my Hensley Tralersaver air hitch.
Yes, the jaws are robust and have a positive hitch action, too. There just is no comparison between fixed vs floating hitches no matter what brand.
When asking for hitch recommendations you should specify fixed or floating. No comparison and that includes price but worth it to me for the rv pin box.
2018 GMC Sierra 3500 DRW 4x4 Duramax/Allison
2014 Lifestyle LS36FW
St Augustine, FL
ependydad
Here and there
Posted: 08/16/19 09:34am Link  |  Quote  |  Print  |  Notify Moderator
pcm1959 wrote:
I agree 100%.
I've gone through a bunch of hitches- two B&W hitches (I upgraded the Companion), then an Andersen Ultimate, and finally a TrailerSaver TS3. I only switched away from the B&W because my new trailer was 21,000 lbs. and the B&W Companion was only rated to 20,000 lbs in the gooseneck/post configuration which is all I had as an option in the 2012 truck I had.
Of them, the TrailerSaver TS3 gives the best ride. But I find it's hitch head more finicky than the B&W. With the B&W, it didn't matter what my last movement was with the truck (forward or backwards). With the TS3, if I last pulled forward, I have to be intentional about putting the truck in neutral and taking my foot off of the brakes or the hitch head binds up.
I think the B&W is an absolute stunner of a product. For most people, it's hard to justify the $3,000 spend on a new TS3. I think you need to plan on towing a lot to justify the cost.
And the B&W wins, hands-down for ease of removing it from the truck. I've never lifted my TS3, it was placed into my truck bed by forklift and then I hang it from the camper between uses. Which, for me, is a hassle as I bring in all slides and raise my steps if I'm going to raise/lower the landing gear on the camper.
2017 Spartan 1245 by Prime Time
2012 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: B&W Turnover Ball + Companion
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
Durb
NW
Posted: 08/16/19 03:50pm Link  |  Quote  |  Print  |  Notify Moderator
I justified the cost of my TS3 after just 30 minutes towing with a B&W Patriot which was a nightmare. I'm in the camp of recommending an air hitch to any newbie, especially those with new trucks and trailers.
* This post was edited 08/16/19 06:07pm by an administrator/moderator *
Cummins12V98
on the road
Posted: 08/18/19 08:06am Link  |  Quote  |  Print  |  Notify Moderator
"I justified the cost of my TS3 after just 30 minutes towing with a B&W Patriot which was a nightmare."
PLEASE tell what was creating a "nightmare" for you with the Patriot?
dryfly
Posted: 08/24/19 08:28pm Link  |  Quote  |  Print  |  Notify Moderator
Big1 wrote:
MFL wrote:
bobbyg123 wrote:
Well, we settled on a B&W Patriot 16,000 non-slider.
Good price, good reviews. Having never used a 5th wheel hitch before, I have no idea how good it is, but it seems to have a good reputation. I'll be pulling a 5th wheel with GVWR under 10,500lbs.
Thanks.
Congrats on your new Patriot!! IMO, from actual use, the best rail hitch available for the dollars spent. You will be very happy with that hitch!!
Jerry
Congrats! It's a good hitch for sure this is the one I have.
In this photo I can see the jaws are definitely around the pin, and the pin box is flat on the hitch head. It's very obvious!
Please....I don't want to create controversy, but I'm curious about the term "high hitch". I assume that's when the flange on the bottom of the pin is set down on the top of the jaws of the hitch.
If that's the case, couldn't that situation be detected by a visual inspection of the jaws? I've been pulling a 5th wheel for years and I've never had that occur once. Seems like one would immediately see space between the pin box and the hitch head. And if it's determined that the pin is correctly in the jaws and is locked in place, I would thank that would minimize the need for a pull test.
Again, I've seen the need for a pull test argued many times on this forum, and I'm not trying to incite that. Just trying to find the way(s) that dropping the trailer is possible.
Cummins12V98
on the road
Posted: 08/25/19 08:21am Link  |  Quote  |  Print  |  Notify Moderator
^^^^^^ OMG another person that has should I say it???? "COMMON SENSE"
Its MUCH easier to "High Hitch the other brands that have thin 1/2" jaws since the plates would be 1/2" closer together compared to a 1" thick jaw B&W.
With a "B&W" it's impossible to drop the RV "IF" the hitch and pinbox plates are touching, the latching handle is closed and locked and the jaws are fully closed around the kingpin. These only require a "VISUAL" test.
I am NOT telling anyone what to do, I am letting people know with open minds and have common sense what they can do.
Mechanical failure is the only way a dropped RV can happen with the B&W using the above method. I am willing to take that chance.
cummins2014
Utah
Posted: 08/25/19 08:38am Link  |  Quote  |  Print  |  Notify Moderator
dryfly wrote:
Big1 wrote:
Thanks.
Jerry
IMO we are a bit hung up on this visual thing. Is there a hitch out there that you can't visually see if the jaws ,bar whatever are closed ??? I can certainly see mine on my Reese hitch.
If you visually see the jaws closed around the pin on the B&W is there also a locking pin or whatever to lock to insure the jaws stay closed ?? My Reese the handle closes, and then there is a pin to insert to lock the handle. I can look at those jaws all day long ,and make sure they are closed, but I am pretty sure if that locking pin is not inserted bad things are going to happen.
My point is we get right back to the pull test. IMO it is "FOOLPROOF" . Apparently its in the B&W manual, that sure has to tell you something. One mentioned something about a Reese Hitch coming undone even after a pull test, thats a new one ,and he did not elaborate , was asked to do so, but like a lot of things on here they just get said without much to back it up .
Probably the only real foolproof way to keep someone from dropping the fifth wheel on their bed was the Blue OX bedsavers they used to sell, but pretty sure they are not available any more. Also there was the Butch device, but you had to make sure that is was closed, or it was useless, those I don't think are for sale anymore.
Page of 11
 > Hitch choice
