RV.Net Open Roads Forum: Fifth-Wheels: 5th wheel lifting bracket
 > 5th wheel lifting bracket
RollandB
Albany, Or
Posted: 08/03/19 07:09am Link  |  Quote  |  Print  |  Notify Moderator
I’ve got a B&W Companion hitch so about six months ago purchased this same lift bracket. I didn’t like the price either but my Chiropractor charges $55 per visit so for me it’s the lesser of two evils. The lift bracket makes easy work with the Companion hitch for removal and installing it back. Money well spent
2005 Silverado 3500 Crew Cab Long Box, Duramax/Allison, B&W Companion, TST507's
2016 Artic Fox 27-5L
C.B.
APPLETON WI USA
Posted: 08/03/19 10:20am Link  |  Quote  |  Print  |  Notify Moderator
Scrap metal pile and a friend with a welder.
Would think 90 percent of us know someone with a welder.
C.B.
CBVP2004~FORD~F350~CC~LARIAT~SRW~SB~4X4~6.0D~
AUTO~PULLRITE 16K SUPERGLIDE~DEMCO GLIDERIDE~
PRODIGY CONTROLLER~C-BETR MIRRORS~EMS-HW50C~
Butch/Barb=2013-Cedar Creek 36CKTS
Kris/Katy=2006-Cherokee 32B
jjj
Lancaster,Ca.U.S.A.
Posted: 08/03/19 10:42am Link  |  Quote  |  Print  |  Notify Moderator
I always wondered if you lift your hitch that way what effect does it have on the jaws with that weight hanging from them. When a fifth wheel is on the hitch there is no weight on the jaws because the head is taking the weight. I was just wondering.
2002 F-350 Crew-Cab Dually
V-10-4.30 gears Mag-Hytec diff.cover
w/Amsoil-6.0 trans cooler Curt Q5 20K hitch & bedsaver
2005 Keystone Challenger 34TBH-Fifth Airbourn
Cummins12V98
on the road
Posted: 08/03/19 10:58am Link  |  Quote  |  Print  |  Notify Moderator
When you go over some of these roads humps and bumps the lift can be HUGE, the hitch is designed for that. So the couple hundred pounds hanging is NOTHING.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
JIMNLIN
Oklahoma
Posted: 08/03/19 12:13pm Link  |  Quote  |  Print  |  Notify Moderator
I've seen different home made devices like that one that lifted from the hitch jaws. One was made from schedule #40 blk pipe....another from a cut off axle shaft.
My hitch plate has 1/2" holes at the ends. I use 1/2" eye bolts and made cables with slip hooks at both ends. Now I can lift it with a old come-a-long hanging from a truss rib in the tractor barn.
mtofell1
Oregon
Posted: 08/03/19 06:46pm Link  |  Quote  |  Print  |  Notify Moderator
Just to make myself feel better I counterweight mine with a jack stand when it's hanging from the pin. I let it hang for years without a problem but figured it couldn't hurt to take some weight off it.
Me Again
Sunbird(Wa)/snowbird(Az)
Posted: 08/04/19 08:05am Link  |  Quote  |  Print  |  Notify Moderator
twinstick wrote:
Demco makes a 5th wheel lifting bracket that looks really nice. Only problem is it's $50. I have a winch in the ceiling of my basement, that for years I've used a strap to pull my hitch out. With my new b&w hitch it would be pretty difficult to use a strap. A friend and I made a few of these lifting bracket for ourselves. Only have a couple dollars in them, and they seem to work really well. They're modeled after the ones from demco, with a few changes.
I would never lift my Patriot(think less expense head) hitch that way or leave it hang on the king pin, as it does not have the pins on each side like the Companion models, that is a second captive feature of the head. Just bumping one of the latch release arms on either side could cause the head to separate from the base.
They make the Companion slider for pucks for all three brands now.
Chris
* This post was edited 08/04/19 09:41am by Me Again *
Cummins12V98
on the road
Posted: 08/04/19 10:37am Link  |  Quote  |  Print  |  Notify Moderator
Good point on the safety aspect hanging the lighter duty Patriot. With the head pins I would not hesitate. My Dad hung his Companion for several years from his PinBox.
twinstick
Ball Ground, Ga
Posted: 08/04/19 03:24pm Link  |  Quote  |  Print  |  Notify Moderator
I'll take my chances. I never touch my hitch when it's hanging. I pull it up, drive out from under it, then drop in on a dolly.
Me Again
Posted: 08/04/19 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
I am going to send B&W a question about lifting that way. Chris
