RV.Net Open Roads Forum: Fifth-Wheels: 5th wheel lifting bracket
 > 5th wheel lifting bracket
2012Coleman
Posted: 08/05/19 04:45am Link  |  Quote  |  Print  |  Notify Moderator
Me Again wrote:
I am going to send B&W a question about lifting that way. Chris
I use the same bracket to lift my B&W slider out, but I never considered this question. Thanks for asking them - and subscribed to this thread.
Experience without good judgment is worthless; good judgment without experience is still good judgment!
2018 RAM 3500 Big Horn CTD
2018 Grand Design Reflection 303RLS
fj12ryder
Platte City, MO
Posted: 08/05/19 07:34am Link  |  Quote  |  Print  |  Notify Moderator
My concern with the B&W hitch would be the stress put on the rubber blocks that support the head. Seems like the hitch would be trying to pull the rubber loose while hanging there.
Howard and Peggy
"Don't Panic"
Me Again
Sunbird(Wa)/snowbird(Az)
Posted: 08/05/19 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
Here is the answer from B&W:
Chris,
Thank you for your inquiry. The head latches are strong enough to hold all the weight of the Patriot. You can lift it out of the truck with the king pin of your trailer. If you have any questions please let me know. I'd be happy to help.
Thank You,
Casey
twinstick
Ball Ground, Ga
Posted: 08/05/19 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
Perfect
Cummins12V98
on the road
Posted: 08/06/19 03:52am Link  |  Quote  |  Print  |  Notify Moderator
Chris,
Thank You,
Casey
Once again the B&W "HeavyWeights" come thru!
But this certainly does NOT suggest other hitches will tolerate such downward forces. [emoticon]
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Dan Henry
Caddo Mills, TX
Posted: 08/08/19 04:52pm Link  |  Quote  |  Print  |  Notify Moderator
I made bracket to remove my BW. Took a piece of steel about 2 X 5 X 1/2. Drilled a 1/2 hole in the middle installers 1/2 eye bolt to put the hook of my chain hoist in. Put the bracket in the king pin hole close the latch then lift the hitch, I am on The road and the bracket is at home or I would post a picture.
Dan
stro1965
Nebraska
Posted: 08/08/19 11:44pm Link  |  Quote  |  Print  |  Notify Moderator
I have something almost identical to that. My dad made it for me years ago.
2018 Ram DRW 3500 6.7
2015 Keystone Fuzion 325
Crodad
Lafayette, LA
Posted: 08/12/19 07:02am Link  |  Quote  |  Print  |  Notify Moderator
Old-Biscuit wrote:
I just use the 5th wheel.......with 5vr hitched I pull the hitch pins and raise it using landing gear legs.
Leave it hanging from king pin.
Ditto. I just use the camper to pull it off.
2008 F-250 PSD 4x2 Lariat
2016 Silverback 31RK
gkainz
Arvada, CO, USA
Posted: 08/12/19 07:54am Link  |  Quote  |  Print  |  Notify Moderator
i have my 6 year old granddaughter lift mine off. [emoticon] (Andersen Ultimate)
'07 Ram 2500 CTD 4x4 Quad Cab
'10 Keystone Laredo 245 5er
Me Again
Posted: 08/12/19 08:11am Link  |  Quote  |  Print  |  Notify Moderator
40 lbs to a 6 year old is like 150 lbs to her grandfather. [emoticon] [emoticon] [emoticon]
