RV.Net Open Roads Forum: Fifth-Wheels: 5th wheel lifting bracket
 > 5th wheel lifting bracket
humblerb
houston
Posted: 08/13/19 09:11am Link  |  Quote  |  Print  |  Notify Moderator
RobWNY wrote:
I mounted a hook to the garage joist and attached an electric winch. Used a tow strap to lift it out. I'll likely just leave it in from now on unless I really have to remove it because the tabs that fit down into the rails for the pins to go through are a pain in the neck to get lined up so all 4 drop in place. My set up is so tight and precise that it took me forever to get it to drop in.
I have the same issue. I just thought the knuckleheads that installed it didn't get the rails aligned just right. I take the top off when I am not using the hitch, but leave the base in for this reason.
It would sure be nice to use my $50,000 truck bed to haul a piece of plywood again. LOL
I've got to figure out a way to get my base off (and back in) without lifting it by hand (I'm old and fat). Thought about something like an engine lift. My shop door is 10' and I can't back in far enough to use the ceiling trusses of the shop.
humblerb
houston
Posted: 08/13/19 09:16am Link  |  Quote  |  Print  |  Notify Moderator
gkainz wrote:
i have my 6 year old granddaughter lift mine off. [emoticon] (Andersen Ultimate)
I, too, have a 6 year old granddaughter.
Never thought of that option.
I love these message boards for great problem solving ideas.[emoticon]
C Schomer
Pueblo West, Co.
Posted: 08/15/19 12:20pm Link  |  Quote  |  Print  |  Notify Moderator
I made this one about 15 years ago. 1 1/2"pipe works great. [image]
twinstick
Ball Ground, Ga
Posted: 08/17/19 08:55am Link  |  Quote  |  Print  |  Notify Moderator
Nice!
whiteeye42
Rock Springs Wyoming
Posted: 08/18/19 08:28pm Link  |  Quote  |  Print  |  Notify Moderator
if you know a welder they could make that for way less than $50 i bet there is not much more than 15 dollars worth of metal
Me,Wife two boys and two dogs
2008 Dodge Ram Quad Cab 4x4 DRW 6.7 cummins
2008 Jayco Eagle 341 RLQS 37' with B&W turnover ball & companion hitch
using rotochoks
add state map
Learjet
Louisiana
Posted: 08/19/19 05:17am Link  |  Quote  |  Print  |  Notify Moderator
Or just buy one for ~$50
https://www.etrailer.com/Accessories-and........UHbC5YSwblh5xFYdeiegnQtdrChoCRLwQAvD_BwE
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2015 Wildcat 317RL, MoRryde rubber pin box, Titan Disc Brakes, Trojan T105
B&W Ram Companion
Yamaha EF2600c tri-fuel generator
Champion Model 46595- 3000/3500w
