RV.Net Open Roads Forum: Fifth-Wheels: Air Conditioner leaking inside...questions
 > Air Conditioner leaking inside...questions
debili
Illinois
Posted: 08/03/19 10:36am Link  |  Quote  |  Print  |  Notify Moderator
Ford Truck Guy WHERE are the weep holes????
Ok I do not get it...trying to check it this morning now it is not leaking at all???
ford truck guy
Pennsylvania
Posted: 08/03/19 11:24am Link  |  Quote  |  Print  |  Notify Moderator
Up on the roof, take iff the AC cover .. There should be about. 1/4” hole in all 4 corners..
Thay may be hard to find, but there are 4.
This may not be your problem, but is something easy to look at ..
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
debili
Illinois
Posted: 08/03/19 11:28am Link  |  Quote  |  Print  |  Notify Moderator
Thank you I was up there but could not figure out where they were...water is running off except on side and as I said now today it isn't even leaking...this is crazy
ford truck guy
Pennsylvania
Posted: 08/03/19 11:53am Link  |  Quote  |  Print  |  Notify Moderator
Once you take the four screws out that hold the shroud on, remove the shroud. You will see a metal tray with rounded edges that everything is sitting in, that is where the whole should be but in all four corners.
Old-Biscuit
Verde Valley
Posted: 08/03/19 12:43pm Link  |  Quote  |  Print  |  Notify Moderator
The weep holes are in the drip pan that is UNDER the EVAP Coil
EVAP COil is in a SEALED compartment Under the roof shroud
You HAVE to OPEN that sealed compartment to access the evap coil drip pan and might have to shift evap coil a bit to get to drain holes to clear them
(cut the tape..remove screws, remove cover. Seal back up after cleaning drip pan AND EVAP Coil)
Look at diagram posted
Evaporator Drain Pan, Evaporator, Room Air Fan.....UNDER the SEALED Cover
(Motor, Condenser, Condenser Blower etc UNDER the roof shroud)
belairbrian
Alabama
Posted: 08/04/19 05:22pm Link  |  Quote  |  Print  |  Notify Moderator
If I missed it, sorry, but I didn't see where anyone asked when this was happening. If it's when rain is falling it's the A/C to roof gasket. If it's not it's a clogged drain hole or blockage where the condensed water vapor runs off the evaporator and out to the drain holes.
TV 2007 Chevy 2500 Long Box Vortec 8.1/Allison
2009 Chaparral 278DS
Reese 16K Slider Hitch, Prodigy 3 BC
USAF Retired
WAR EAGLE
RICK-ards Red
Ontario
Posted: 08/04/19 05:56pm Link  |  Quote  |  Print  |  Notify Moderator
We had a Jayco with a A/C that leaked inside as well, it was the bolts holding it that were loose and did not compress the gasket at all. How the A/C unit stayed on the trailer going down the Hwy was a miracle.
opnspaces
San Diego Ca
Posted: 08/06/19 05:45pm Link  |  Quote  |  Print  |  Notify Moderator
Try this link to see how to check the drain holes. Link
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
debili
Illinois
Posted: 08/15/19 05:55am Link  |  Quote  |  Print  |  Notify Moderator
Hi all,
well I have done everything short of calling the RV place to come out. I have been on roof several times cleaned it out and think I got the drain holes cleared.
It is still leaking in the liv room but now is mostly just when I turn it off...it is just weird I have checked the bolts so I just do not know...thanks everyone for your help!
debili
Illinois
Posted: 08/15/19 06:05am Link  |  Quote  |  Print  |  Notify Moderator
ok after following that link which I did not see until after my first reply...it says to remove that evaporator cover which I was tempted to do each time but was afraid of shock...so I may get up there again. it has a warning on unit that even if turned off you can still be shocked...I assume unplugging the whole RV from elec would avoid this from happening...it is a bit difficult doing this with only one person as it might be helpful to have it turned on once the shroud is off and evaporator cover off to see where the water is coming out...I do not want to have it running while I take the shroud off...hum challenging![emoticon]
oh yes and it has nothing to do with the rain
