RV.Net Open Roads Forum: General RVing Issues: Replacing all my bulbs with LEDs
 > Replacing all my bulbs with LEDs
time2roll
Posted: 08/03/19 09:33pm Link  |  Quote  |  Print  |  Notify Moderator
craig7h wrote:
Can I ask a question, did you find the leds put off more heat than the standard bulbs.
The energy savings of LED is primarily from the reduction of waste heat.
Incandescent is basically a heater that puts out a bit of light.
LED is primarily a light source with a small bit of heat.
675w Solar pictures back up
JimK-NY
NY
Posted: 08/04/19 05:41am Link  |  Quote  |  Print  |  Notify Moderator
Just a few points to consider:
There are a lot of cheap LED bulbs available. Spend a bit more and buy bulbs that are rated for up to 15 volts or so. LED trailer lights, and Superbright are two websites that carry quality bulbs.
Any LED bulb can interfere with radio reception. I have not figured out why or any pattern that explains this. I have changed bulbs of the same brand and seen the issue come and go.
Buy only a few bulbs at first and decide the temperature range you like. A bulb with an output of around 3000K will duplicate old incandescent bulbs and will give a yellow tint to everything. I liked that for a while because I was used to it. Now I have changed over to bulbs that are around 5000K. That is closer to sunlight and a cleaner look. Now everything just seems to look dingy with the warm bulbs.
Consider replacing the fixtures instead of just changing to LED bulbs. The fixtures are inexpensive and have easier to use switches than my old fixtures.
Deb and Ed M
SW MI & Space Coast, FL USA
Posted: 08/04/19 07:07am Link  |  Quote  |  Print  |  Notify Moderator
I noticed a difference in interior temps on our pop-up truck camper (no A/C) when I switched to LED bulbs - it was much cooler when they were on!
C Schomer
Pueblo West, Co.
Posted: 08/04/19 01:49pm Link  |  Quote  |  Print  |  Notify Moderator
I also found its very helpful to buy from vendors that show a picture of their actual lights and that avoids the problems with vendors that say they are bright white and they are actually yellow and vice versa. I've had good luck with cheap bulbs and if I can find a picture showing the actual light color, I don't have to throw any of them away anymore! Craig
Lynnmor
Red Lion
Posted: 08/04/19 03:33pm Link  |  Quote  |  Print  |  Notify Moderator
The voltage regulator in the higher priced lamps is what causes TV interference, the real cheap ones may not have a regulator. I bought the cheap lamps on eBay for that reason and they are working well. Look for the voltage range that is specified and if it is wide, there is a regulator.
CharlesinGA
South of Atlanta, Georgia
Posted: 08/05/19 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
PFitt wrote:
Yeah I went with M4 Products pricey but much better quality and the Elite series in the natural white 4500k are awesome!!
M4, nuff said.
Charles
dcmac214
SW OKLA
Posted: 08/06/19 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
I did that in the 5er a few years ago. Big difference in the light given off. Having finally done it, wish I'd done it the day after we got it home.
Had a terrible time with a lot of the LEDs because of the rough (ceramic?) base that wouldn't easily slip into the fixtures. A miniscule dab of dielectric grease solved that.
CharlesinGA
Posted: 08/06/19 09:49pm Link  |  Quote  |  Print  |  Notify Moderator
To expand somewhat. I bought the plate type LED lights from M4.
http://www.m4products.com/plate-style-led-lights/
And removed the existing sockets in the ceiling fixtures, and cut off the socket adapter ends on the wires and spliced in the wires in the place of the original sockets. I removed the heat shield/reflectors and stuck the flat plates in their place. I used both 24 and 48 element lights depending on the area I was lighting. I used the natural white, not the cool white (bluish) or the warm white (yellowish). having the LEDs mounted on an aluminum plate spaced from the circuit board with the driver, makes it operate very cool and they last forever.
For the bi-pin (G4) reading lights with halogen bulbs, I used the Elite series and had one fail in the motorhome, M4 promptly replaced it. Only failure of any kind I've had with their products.
I started out with cheaper LED lights to replace the original bulbs and the LED elements failed very quickly, no heat sinks.
Charles
TravelinDog
Nevada
Posted: 08/09/19 01:17pm Link  |  Quote  |  Print  |  Notify Moderator
I just replaced all the bulbs in my TT with cheapo LED's from Amazon. Got a 10pk for just over $10. They are the bright bluish lights but once I put the opaque covers back on the light fixtures you can't tell the difference.
Being that we only use the trailer about 3-4 weeks out of the year I'm sure they will outlive the trailer.
Saving my batteries when we are out in the boonies was my primary goal. I try to run the gen as little as possible.
* This post was edited 08/10/19 03:53pm by TravelinDog *
camperdave
northern, California
Posted: 08/09/19 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
yeah, it's hard to justify $10/bulb when they are available at $1/bulb on ebay and amazon. I just replaced my exterior porch light with an LED fixture (due to the bulb overheating and melting the wire off the socket! [emoticon] ). Now that I've seen it in person, I'd like to convert them all. Seeing the Trimetric go up .2a with the light on is awesome.
I'm currently (get it? ha) debating retrofitting with the panels from M4, or just replacing the entire housing. The pricing is not far off between the two. I may just do the three main lights that we use for now and see how it goes. Maybe I'll pick up a few of each, and a bucket of cheapo's for the lights we rarely use.
2004 Fleetwood Tioga 29v
