RV.Net Open Roads Forum: Fifth-Wheels: Short Beds w/out Sliding Hitch
 > Short Beds w/out Sliding Hitch
GaryUT
Northern UT
Posted: 08/04/19 10:38pm Link  |  Quote  |  Print  |  Notify Moderator
I have a short bed GMC with a patriot slider. The dealer who installed it set as far back as it would go. The pin box will hit the tailgate when the hitch is slid back:
I have since adjusted the hitch forward 3 inches, it will just clear the tailgate on level ground. I will have to lower the tailgate to use the slider.
Gary
2019 Keystone Laredo 255SRL
2009 GMC Sierra 2500 4x4 Crew cab short bed
Ski Pro 3
bye
Posted: 08/04/19 10:41pm Link  |  Quote  |  Print  |  Notify Moderator
Gary
This is why they sell those 5th wheel tail gates.
garyp4951
TN
Posted: 08/05/19 06:07am Link  |  Quote  |  Print  |  Notify Moderator
GaryUT, I just did that yesterday with my new slider, now I thinking about going back to my regular Companion. Luckily I just scraped the rubber cap pretty bad.
RCMAN46
NorthWest
Posted: 08/05/19 06:59am Link  |  Quote  |  Print  |  Notify Moderator
Gary
Does your pin box clear the bed sides when you come close to a 90 degree turn?
Allworth
Orlando, FL
Posted: 08/05/19 12:45pm Link  |  Quote  |  Print  |  Notify Moderator
GaryP,
My son has a Dodge quad-cab with that same dent. They must install them at the factory on short beds!
They are an extra cost option for my long bed Chevy.
A
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Jeeps have round headlights"
schlep1967
Harrisburg, PA
Posted: 08/05/19 01:22pm Link  |  Quote  |  Print  |  Notify Moderator
cattledog04 wrote:
Just curious how many people don't have a sliding hitch with their shortbeds? I never used it on my old truck, and I'm trying to decide to buy another (spending more) for my HD that's on order or just get a non slider. Thoughts?
My opinion so feel free to ignore. If you are buying a sliding hitch, buy an auto slider. Otherwise, you will not slide the hitch when you need to. Crowded gas stations get many when going forward and trying to maneuver. Stopping when your camper is blocking traffic as you try to make a sharp turn to get to a pump, backing up to get straight so you can get out and release the slide, getting in to pull forward, getting out to lock the slide and finally getting back in to turn to get to the pump.....
Auto slide is easy and works every time without thinking about it.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
handsome51
Baytown
Posted: 08/05/19 08:51pm Link  |  Quote  |  Print  |  Notify Moderator
If you are going to buy another truck. Why not get a real truck that has a 8ft bed. Then you don't need a slider. Go ahead and splurge a little more and buy you a good air hitch. Then you can travel down the road in comfort. You won't be jerked around in the truck and everything in the 5th wheel will ride smoothly. Just splurge one time and you won't regret it. I did 13 years ago this month. I already had the truck. I bought I brand new Carriage 5th wheel and a 25k Air Safe Hitch. On the first trip as we are traveling down the highway. The wife said you don't even know the 5th wheel is back their. The only time something moves in the 5th wheel is if I have to make a emergency hard stop with the brakes.
cattledog04
Temecula, CA
Posted: 08/05/19 09:22pm Link  |  Quote  |  Print  |  Notify Moderator
I appreciate everyone's opinion. Not a fan of long beds, plus I'm splurging enough as it is with ordering my 2020 HD.
prstlk
Post Falls ID
Posted: 08/05/19 10:29pm Link  |  Quote  |  Print  |  Notify Moderator
Many many miles on our 2013 f 350 short bed towing a big 5th wheel. Anderson hitch no problems. Yes you have to pay attention as you don't have the radius of a long bed hitch or a slider. Unless your trying to park in super small spots with little room to move the short bed is fine. Also keep in mind that a full size PU is harder to park and manuver then a short bed when the 5ver is not behind you.
2007 Keystone Challenger 5th wheel, Ford F350 Super Duty 6.7L Diesel, Short Bed, 2 dogs and the cat and rolling down the road full time since May 2014
GaryUT
Northern UT
Posted: 08/05/19 10:51pm Link  |  Quote  |  Print  |  Notify Moderator
RCMAN46 wrote:
Gary
I have plenty of clearance between the pin box and the sides of the bed, I can turn the truck to 90 degrees. When the hitch was installed the dealer set it as far back as it would go, the pivot point of the hitch was 3" behind the axle. Since the picture was taken I have adjusted the hitch to be centered over the axle, the pin box will clear the tailgate on level ground, but not by much.
Gary
