RV.Net Open Roads Forum: Atwood Water Heater Tank Crack Repair ? UPDATE
 > Atwood Water Heater Tank Crack Repair ? UPDATE
lane hog
Tucson, AZ & NW Chicago Burbs, IL
Posted: 08/12/19 11:13pm Link  |  Quote  |  Print  |  Notify Moderator
Replace the tank...
You'd have to disassemble the halves of the tank to get to the burner tube, and by that time, the labor would exceed what it takes to get a new tank.
PEX itself won't be susceptible to freeze damage, but the fittings are, particularly at a low point where water might have collected.
  • 2005 Winnebago "Minnie" 31C (was a three-time Jayco owner)
  • 2012 MasterTow Dolly pulling a Honda Odyssey or Insight (had Ram 2500 CTD, Durango, Liberty...)
  • Onan Microquiet 4000, plus 130W solar and Honda EU2000i twins for backup
BFL13
Victoria, BC
Posted: 08/13/19 04:49pm Link  |  Quote  |  Print  |  Notify Moderator
Old-Biscuit wrote:
BFL13 wrote:
I know Atwood has a different tank material from Suburban so it does not need an anode in the drain plug. Hers has that plastic plug for an Atwood. I don't have the model number, but it does have 120v and propane. Trailer is about 10 years old. More later if required. Be a few days.
Atwood Aluminum'
Suburban STEEL Tank...which has a glss-lining sprayed inside hence the andoe rod requirement
Trailer 10 yrs old and is combo electric/gas
If 6 gallon.....GC6A-10E Model
If 10 gallon....GC10A-4E Model
Replacement tanks available for each
NEW complete water heater replacement available
I have a line on a GC6A-7E from a 98 Southwind Class A. Would that fit in the hole in the side of the TT her GC6A-10E goes into? Lots of room inside the TT where the WH goes, so it is just the access in the side of the TT that matters AFAIK. Thanks.
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
Old-Biscuit
Verde Valley
Posted: 08/13/19 10:33pm Link  |  Quote  |  Print  |  Notify Moderator
Cut out openings
6 gallon
12 1/2"H X 16"W X 19 1/2"D
10 gallon
15 1/2"H X 16"W X 20 3/4"D
6 for 6 and 10 for 10
Her newer version can be replaced by the earlier version
AC side needs 120V AC to on/off switch then to separate set of T-stat/ECO on backside of water heater tank then to element
OEM ON/OFF is also back there
DC side for propane....12VDC to On/Off switch then to thermal fuse to t-stat (then OEM wiring to control board to eco to gas valve)
Atwood Water Heater Info
* This post was edited 08/13/19 10:40pm by Old-Biscuit *
BFL13
Victoria, BC
Posted: 08/13/19 11:11pm Link  |  Quote  |  Print  |  Notify Moderator
Old-Biscuit, thanks for your info on all this. Very helpful! [emoticon]
mchero
Henniker, NH
Posted: 08/15/19 06:58pm Link  |  Quote  |  Print  |  Notify Moderator
I removed a HWH that was froze solid! Looked like a beach ball!
Had to pull it out thru the back of a bookcase! Would not fit thru the opening. If it was indeed frozen i bet it did more than just crack.
Replace it!
Robert McHenry
Currently, Henniker NH
07 Fleetwood Discovery 39V
1K Solar
2005 Jeep Grand Cherokee
Prior:1993 Pace Arrow 37' Diesel
BFL13
Victoria, BC
Posted: 08/15/19 07:27pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, I should know more in a few days. I watched the 46 minute youtube mentioned earlier, yipes! I am hoping for a swap out of the whole thing, but it still looks like quite a chore.
BFL13
Victoria, BC
Posted: 08/16/19 05:47pm Link  |  Quote  |  Print  |  Notify Moderator
Turns out the one in the 98 Southwind is a G6A-8E 6.2 US Gal, and the busted one in the 08 TT is a G6A-8E 6.0 US Gal according to their stickers.
Those are gas only. A "C" in the model number is for "combination gas and AC electric"
* This post was edited 08/17/19 10:59am by BFL13 *
