RV.Net Open Roads Forum: Fifth-Wheels: proper hook up procedure?
 > proper hook up procedure?
Page of 5
obie311
Aux Arcs
Posted: 08/04/19 06:46pm Link  |  Quote  |  Print  |  Notify Moderator
No, I'm not looking for dating advice. Happily married for many years.
What's the best practice to keep the trailer from rolling backwards as you back the fifth wheel hitch under the trailer? I'm worried about stressing and jamming the front leveling legs with an aft motion. My 5'er came with a Lippert Ground Control 3.0.
Do you use rubber chocks on the trailer wheels? Can you just jerk out the break-away switch and electrically lock the trailer wheels even if the brake umbilical is not yet attached to the tow vehicle?
mtofell1
Oregon
Posted: 08/04/19 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
Definitely use wheel chocks. The trailer brakes are nowhere near adequate for hooking up. Also, best practice is to have the 5th king pin a bit lower and have the hitch "lift" the trailer as it latches. This takes weight off the legs and helps prevent what you are talking about. 5th hitches have a bit of a ramp, presumably for this exact reason.
dieseltruckdriver
Black Hills of SD
Posted: 08/04/19 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
Always chock the wheels. It amazes me how many people don't. The trailer brakes will not even work until the trailer moves.
2000 F-250 7.3 Powerstroke
2018 Arctic Fox 27-5L
Old-Biscuit
Verde Valley
Posted: 08/04/19 07:08pm Link  |  Quote  |  Print  |  Notify Moderator
FIRST thing ON.....WHEEL CHOCKS
LAST thing OFF.....WHEEL CHOCKS
agesilaus
North Florida
Posted: 08/04/19 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
Double ditto
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
azdryheat
Tucson, AZ
Posted: 08/04/19 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
I use rubber chocks on my personal trailer. At work nothing is used; never any problems with them rolling.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2011 Harley Ultra Limited
2016 RZR 900
B.O. Plenty
Minnesota
Posted: 08/04/19 08:10pm Link  |  Quote  |  Print  |  Notify Moderator
I use chocks and raise the trailer until the hitch is about 1/2" above the fifth wheel plate. I then back into in at it latches. I leave the front jack legs down and never have had a problem. I don't slide the hitch up the plate as it will put a strain on the jacks.
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
valhalla360
No paticular place.
Posted: 08/04/19 09:05pm Link  |  Quote  |  Print  |  Notify Moderator
Trailer brakes need the wheel to turn a bit to engage, so that's not viable.
Use chocks but realistically, unless you get crazy slamming into the trailer, it's not an issue.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
MarkTwain
Northern, Ca. , USA
Posted: 08/04/19 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
Then remove the chalk after you have raised the front jacks about an inch from the ground. Then do the "bump test" by using the brake lever lock up the trailer brake, then pull the trailer forward about 6 inches to make sure you have the hitch hooked up correctly, then raise your front jacks completely up.
time2roll
Posted: 08/04/19 09:35pm Link  |  Quote  |  Print  |  Notify Moderator
+1 more for using wheel chocks.... and not pulling the brake switch.
675w Solar pictures back up
Page of 5
