RV.Net Open Roads Forum: Fifth-Wheels: proper hook up procedure?
 > proper hook up procedure?
Page of 5
obie311
Aux Arcs
Posted: 08/04/19 11:46pm Link  |  Quote  |  Print  |  Notify Moderator
OK I've got it now. Rubber chocks from Horrible Freight OK?
I do the "bump" test now but the advice to only slightly raise the front legs makes a lot of common sense in case the hitch is not fully latched.
Thanks for the help.
2012Coleman
Posted: 08/05/19 04:30am Link  |  Quote  |  Print  |  Notify Moderator
mtofell1 wrote:
Definitely use wheel chocks. The trailer brakes are nowhere near adequate for hooking up. Also, best practice is to have the 5th king pin a bit lower and have the hitch "lift" the trailer as it latches. This takes weight off the legs and helps prevent what you are talking about. 5th hitches have a bit of a ramp, presumably for this exact reason.
X2
Experience without good judgment is worthless; good judgment without experience is still good judgment!
2018 RAM 3500 Big Horn CTD
2018 Grand Design Reflection 303RLS
gkainz
Arvada, CO, USA
Posted: 08/05/19 08:02am Link  |  Quote  |  Print  |  Notify Moderator
Those are the ones I use. Cheap and effective.
'07 Ram 2500 CTD 4x4 Quad Cab
'10 Keystone Laredo 245 5er
schlep1967
Harrisburg, PA
Posted: 08/05/19 08:35am Link  |  Quote  |  Print  |  Notify Moderator
B.O. Plenty wrote:
I use chocks and raise the trailer until the hitch is about 1/2" above the fifth wheel plate. I then back into in at it latches. I leave the front jack legs down and never have had a problem. I don't slide the hitch up the plate as it will put a strain on the jacks.
B.O.
This is a recipe for disaster with many fifth wheel hitches. It may be what your manufacturer says to do and if it is, great.
OP your hitch manufacturer has instructions for your model hitch. Follow them and only them as to the height of your hitch when hooking up to the trailer.
Yes to the chocks. The cheap yellow ones from walmart work fine. Just make sure you look at them closely. Very few know that they have an expiration date on them.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
bobsallyh
Livingston, TX.
Posted: 08/05/19 09:30am Link  |  Quote  |  Print  |  Notify Moderator
Always use wheel chocks! I've heard too many folks with veed truck beds say "but the ground looked level". The company I worked for, if you didn't chock, take the next day off in the street with no pay.
rhagfo
Portland, OR
Posted: 08/05/19 09:34am Link  |  Quote  |  Print  |  Notify Moderator
agesilaus wrote:
Old-Biscuit wrote:
FIRST thing ON.....WHEEL CHOCKS
LAST thing OFF.....WHEEL CHOCKS
Double ditto
Abot X15 by now I always chocks the wheels!!! ALWAYS!!!
rhagfo
Portland, OR
Posted: 08/05/19 09:37am Link  |  Quote  |  Print  |  Notify Moderator
B.O.
This is a great way to HIGH HITCH!!
If you are worried about the hitch riding up the hitch due to stress, doing that is far less the running down the road!
time2roll
Posted: 08/05/19 09:52am Link  |  Quote  |  Print  |  Notify Moderator
I always hitch low and let it ride up the saddle. High hitch will jam up the Pullrite hitch and maybe others. 1/4" or 2" low works fine for me.
675w Solar pictures back up
mtofell1
Oregon
Posted: 08/05/19 10:29am Link  |  Quote  |  Print  |  Notify Moderator
Years ago I remember walking by a loading bay behind a store and there were HUGE signs saying, "drivers responsible for chalking their own wheels," and it stuck with me. Basically, don't trust anyone else to do this absolutely critical step in hooking/unhooking.
Also, fwiw, those yellow plastic cheapies from Walmart work fine until you run over/crush them. Once the vertical supports have been crushed the whole thing will collapse easily. I have used those plastic ones but have also just used chunks of firewood a lot over the years. Replacements are cheap and easy to find [emoticon]
Gjac
Milford, CT
Posted: 08/05/19 10:46am Link  |  Quote  |  Print  |  Notify Moderator
Doesn't it depend on the type of hitch you have as to whether or not you use chocks? I watched a video yesterday that Dutchmansport posted of the pros and cons of the various hitch arrangements. It looked like the truck with the Anderson hitch just backed up under the 5th wheel hitch then the 5th wheel was lowered onto the ball. Do you still need chocks for this type of hitch?
Page of 5
