RV.Net Open Roads Forum: Dinghy Towing: Tow Dolly resurrection
Search only in Dinghy Towing
 > Tow Dolly resurrection
Brian in Michigan
S.E. Mi.
Posted: 08/06/19 01:19pm Link  |  Quote  |  Print  |  Notify Moderator
I have an old tow dolly that I want to put back into service. It does not have brakes on it. I am wondering what is a better braking setup, drum brakes or disc brakes using the surge controller. I am more concerned with towing in the mountains than on flat land.
1990 GEORGIE BOY 28' 454 4BBL, TURBO 400 TRANS,
CAMPING: WHERE YOU SPEND A SMALL FORTUNE TO LIVE LIKE A HOMELESS PERSON.
BarneyS
S.E. Lower Michigan
Posted: 08/06/19 02:00pm Link  |  Quote  |  Print  |  Notify Moderator
Moved to Dinghy Towing forum from Towing.
mowermech
Billings, MT
Posted: 08/07/19 11:38am Link  |  Quote  |  Print  |  Notify Moderator
I was going to put brakes on an old Demco Kar Kaddy a few years ago, then I found out that the spindles had no flange to mount the backing plate on. I gave up on that idea. I quit towing the PT Cruiser instead.
You might want to check to see what is required for your dolly to install brakes. It quite possibly might be easier to find a dolly with brakes instead of trying to install them on your old dolly.
As for drums or discs, I don't know which would be "best" in the mountains. Same goes for electric or surge. I have used both on various trailers in the past. They both worked just fine for me.
CM1, USN (RET)
Daily Driver: '06 PT Cruiser Turbo
Toad: '05 Wrangler Unlimited
Toy: 1999 Dodge QC LWB, Cummins, Auto, 4X4
Other toys: 2 Kawasaki Brute Force 750 ATVs.
Brian in Michigan
S.E. Mi.
Posted: 08/07/19 01:41pm Link  |  Quote  |  Print  |  Notify Moderator
I do have the flange on the spindle
lane hog
Tucson, AZ & NW Chicago Burbs, IL
Posted: 08/13/19 12:45am Link  |  Quote  |  Print  |  Notify Moderator
Do you want the brakes to work, or just to be there for an emergency break-away situation?
We have drums with the surge actuator on our dolly for a break-away only, and having pulled thru the mountains multiple times never really felt that we needed added braking from the dolly.
  • 2005 Winnebago "Minnie" 31C (was a three-time Jayco owner)
  • 2012 MasterTow Dolly pulling a 2003 Jeep Liberty (had Ram 2500 CTD, Dodge Durango, Honda Odyssey...)
  • Onan Microquiet 4000, plus 130W solar and Honda EU2000i twins for backup
Bipeflier
Centralia, MO
Posted: 08/19/19 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
I have disc surge brakes on my boat trailer. They work great!
2010 Cruiser CF30SK Patriot
2016 3500 Duramax
1950 Right Hand Seat GPS (she tells me where to go)
