RV.Net Open Roads Forum: Class C Motorhomes: headlight switch on 1978
 > headlight switch on 1978
Capt Steve
central CA
Posted: 08/06/19 01:54pm Link  |  Quote  |  Print  |  Notify Moderator
Problem- gauge lights quit working, 1978 Dodge Class C. Has anyone replaced their headlight switch? I need to know which parts of the dash to remove to reach the switch. I have removed the panel under the steering column. Should I post this in a different section?
My rig's a little old but that don't mean she's slow.
77rollalong
Brighton Ontario
Posted: 08/06/19 02:39pm Link  |  Quote  |  Print  |  Notify Moderator
most of thouse switches you pull the knob out as far as you can, and there is a button on the back you push and the knob will pull all the way out, then just have to undo the nut on front of the dash and the switch comes out..
Capt Steve
central CA
Posted: 08/10/19 08:52am Link  |  Quote  |  Print  |  Notify Moderator
Got it done. I made a HOW-TO file.
1978 DODGE HEADLIGHT SWITCH
