RV.Net Open Roads Forum: Beginning RVing: RV toilet paper
 > RV toilet paper
Page of 6
parametric
Kamloops, BC. Canada
Posted: 08/06/19 06:46pm Link  |  Quote  |  Print  |  Notify Moderator
Been using Costco Kirkland brand for years. It passed the 30 second in jar test and breaks down easily.
philh
Belleville MI
Posted: 08/06/19 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
Another good choice is Aldi's
Boon Docker
I use Charmin. It does not pass the 30 second break down test, but I have never had any problem with it.
dieseltruckdriver
Black Hills of SD
Posted: 08/06/19 08:42pm Link  |  Quote  |  Print  |  Notify Moderator
We used to use Angel SOft but have recently switched after watching this video.
RV toilet paper test.
2000 F-250 7.3 Powerstroke
2018 Arctic Fox 27-5L
Cocky_Camper
Rock Hill, SC
Posted: 08/07/19 08:56am Link  |  Quote  |  Print  |  Notify Moderator
Just get single ply septic safe, and your shouldn't have any issues.
2004 Sea Breeze by National RV - 8341
Former Coaches:
2006 Keystone Zeppeline 291 - TT
2000 Aerolite Cub F21 - Hybrid TT
1991 Coleman Pop Up
Formerly known as: hybrid_camper
myredracer
Langley B.C.
Posted: 08/07/19 11:03am Link  |  Quote  |  Print  |  Notify Moderator
Same here. In the beginning, we bought a few household and RV branded TP and did the jar test. The Kirkland breaks down nicely into little pieces. Same with a regular household brand or two (can't recall, Scotty maybe?) Interestingly, one RV TP brand broke into small pieces and one didn't, Thetford IIRC.
Thing is, there is no industry regulation on RV TP grading and specs so they can call it whatever they want and charge mafia prices for it. [emoticon] Same with "septic safe" labeling.
Does it matter if it breaks down into little pieces or not? Dunno and I think opinions are divided equally. For us, the Costco TP is cheap and breaks down so that's what we use. If you have a clear elbow on your sewer hose, you can see blobs of white stuff flowing through it and I doubt it matters if the blobs are a mass of individual little pieces or made up of continuous sheets attached together. One thing for sure, it's never in there long enough to biodegrade like in a septic tank.
Gil, Deb & Dougal a 15 year old Springer Spaniel
2014 KZ Spree 262RKS, Reese DC WDH, shocks and Endurance LRE tires
2012 GMC Sierra 2500HD crew cab, Bilstein shocks, heavy duty trailering option
Allworth
Orlando, FL
Posted: 08/10/19 12:30pm Link  |  Quote  |  Print  |  Notify Moderator
You do not have a septic system that processes waste!
The RV has a HOLDING tank.
Toilet paper brand and type is of absolutely NO importance and has NO impact on how a holding tank works or doesn't work. Plenty of water and frequent emptying and flushing with plenty of clean water ARE important.
Yes, my degree IS in Civil and Sanitary Engineering. A long time ago, maybe, but poop is still poop.
A
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Jeeps have round headlights"
Lynnmor
Red Lion
Posted: 08/10/19 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
A
The campground may have a septic system.
Matt_Colie
Southeast Michigan
Posted: 08/11/19 09:27am Link  |  Quote  |  Print  |  Notify Moderator
Septic safe or not.....
If it does not break down in the jar test, don't even put it aboard.
Background Story:
My daughter put a wipe in the pot. First it jammed the valve in the pot, but somehow she got it loose and never said anything.
Then when dumping, the flow would not start. I got it started and I still didn't know about the wipe. At the next dump, the pipe was full because the slide valve was leaking for three days.
When I got the chance to back-flush the valve, the wipe (now a week or more old) still had enough strength to plug up the back-flush set.
I got the wipe free and now everything was working as it should. I showed the wipe to DW. She told me DD have brought those along and though she knew that they should not go into the pot.......
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs going to see some dry places that have Geocaches in a coach made the year we married.
Allworth
Orlando, FL
Posted: 08/11/19 01:14pm Link  |  Quote  |  Print  |  Notify Moderator
I have a septic tank at home. We use whatever brand of toilet paper is on sale at Publix. After 47 years and two kids in the same house my tank has had to be pumped twice for accumulated solids.
I do not have a garbage disposer in my sinks and we do not discharge the clothes washer into the tank (grey water dry well).
Again! Toilet paper is NOT a problem.
Page of 6
 > RV toilet paper
