RV.Net Open Roads Forum: Fifth-Wheels: A/C flipping breaker
 > A/C flipping breaker
Bird Freak
Dallas Ga.
Posted: 08/07/19 08:46am Link  |  Quote  |  Print  |  Notify Moderator
cavie wrote:
ETCrockett wrote:
I’m guessing your FW is 50 amp service and you said you were tripping a 20 amp breaker. Sounds like you are using adapters to plug into a regular household outlet in your garage. This can be a problem depending what else is drawing current in the FW or possibly in your house on the same circuit. I used to have this same issue on my TT with 30 amp service plugged into a household outlet. Especially in July and August when it is the hottest. Try running your AC in the evening after the outside temperature has cooled down. See if it runs longer than 30 minutes. If that works, you might see if you can find someone with a 50 amp box or generator where you can get 30 to 50 amps of continuous power and see if that solves your problem.
My guess is he is tripping the 20 amp breaker in the trailer marked A/C'
Change out the breaker. It.s cheap at Lowes, HD. Could be defective.
Buy new run and start caps. Some units have 1 ea. Some have a combo.
You are exactly right. I think this is what Im going to do. Parts are getting old.
Eddie
03 Fleetwood Pride, 36-5L
04 Ford F-250 Superduty
15K Pullrite Superglide
Old coach 04 Pace Arrow 37C with brakes sometimes.
Owner- The Toy Shop-
Auto Restoration and Customs 32 years. Retired by a stroke!
We love 56 T-Birds
Frank55
Posted: 08/08/19 06:47pm Link  |  Quote  |  Print  |  Notify Moderator
Mine was doing the same thing. Turns out the compressor fins were dirty. Clean those and everything was fine.
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 08/08/19 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
Before changing the Breaker, pull the panel off the Distribution Box where all the Breakers are, and with AC power removed from the unit, check the tightness of the wire connections on the breaker that's tripping, and while in there check all the other Breakers too.
Had the same exact problem with a Dryer in a Mobile Home and that was all the problem was, just loose connection causing excessive current and tripping the breaker.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
colliehauler
Mc Pherson KS USA
Posted: 08/08/19 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
I would agree with this as well. If it is as been sitting for three years outside could be clogged with debris. If so the compressor will draw more amps then normal.
sayoung
Tx
Posted: 08/09/19 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
Bird Freak wrote:
Ok guys, here's the problem.
I have not been able to use 5er much for 3 years since stroke and heart attack. Just a couple of winter runs when a/c was not needed. So I'm checking everything out and my a/c runs and cools fine for about 30 minutes the flips breaker. Seems to be pulling to many amps for some reason. I'm going topside tomorrow and pull cover and clean coils. What else should I look for while the cover is off.
Unit starts easy and runs cool until it flips. Car a/c systems I know well but not this thing.
Unit is a dometic 13.500
As a retired AC tech, from your description I would start at breaker & check terminal for tightness. Loose connection causes heat along with higher resistance which makes for higher amps. When breaker trips is it pretty warm to the touch , maybe even HOT ? Check for arcing on breaker & bus bar . Do these checks before getting on the roof .
Bird Freak
Dallas Ga.
Posted: 08/18/19 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
Just to update guys. The hard start capacitor seems to have solved my problems.
Going camping this weekend and if it still has a problem I will update.
Thanks for all the suggestions.
blofgren
Surrey, B.C.
Posted: 08/18/19 10:24pm Link  |  Quote  |  Print  |  Notify Moderator
Glad to hear you have solved it! We were just in desert country for 3 weeks and I was a bit nervous about our 11 year old air conditioning unit, but it kept going with no issues.
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, RAM 20k sliding hitch, Retrax, Linex, and a bunch of options incl. cargo camera
