RV.Net Open Roads Forum: Tech Issues: Dometic 15K A/C Blowing Warm/Hot Electric Smell?
 > Dometic 15K A/C Blowing Warm/Hot Electric Smell?
ENG2242
Missouri.
Posted: 08/06/19 05:51pm Link  |  Quote  |  Print  |  Notify Moderator
Hey guy's,
My Dometic 15K A/C is blowing warm air and has a distinct smell. I'm not sure if it's hot electric or not. Breakers are off! It is only four months old and I'm have a heck of time finding a mobile RV tech near St Louis. As most, I've had a rig for decades and been in/out of these doing self repair. I have no inside access to the unit in order to check it. With that, where should I start? I hope to find a tech for warranty, however, it's time to get the ball rolling on figuring this out.
Also, these new digital thermostats that have an "auto" mode vary the fan speed from high to low accordingly. I'm not convinced I like that feature, as the speed fluctuates regularly. I always ran my units on direct high in the heat/humidity. Thought's??
Thanks,
David
* This post was edited 08/06/19 05:57pm by ENG2242 *
David Hartmann
2018 Bighorn 3870FB
2007 Dodge Ram 2500 CTD 5.9
Prodigy 2
Auto-Slide Hitch
Firestone Air-Bags
midnightsadie
ohio
Posted: 08/06/19 06:14pm Link  |  Quote  |  Print  |  Notify Moderator
does it have a heat strip thats on?
ENG2242
Missouri.
Posted: 08/06/19 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
This unit does not have heat strips.
bdpreece
Yuma Arizona / Oregon Traveler
Posted: 08/06/19 08:41pm Link  |  Quote  |  Print  |  Notify Moderator
My first guess would be the start up capacitor. A fairly easy and inexpensive fix. If you are reasonably mechanically inclined and feel comfortable getting on the roof you can change it in probably 20 minutes and, that includes the climbing time.
If you decide to do this make sure you short the electrical terminals on the capacitor together before touching the capacitor as they can bite.
Brian, Loretta & Daisy (Golden Retriever)
2008 Holiday Rambler Endeavor PDQ40
2014 Ford Explorer toad
cavie
Posted: 08/07/19 05:37am Link  |  Quote  |  Print  |  Notify Moderator
ENG2242 wrote:
Hey guy's,
My Dometic 15K A/C is blowing warm air and has a distinct smell. I'm not sure if it's hot electric or not. Breakers are off!! It is only four months old and I'm have a heck of time finding a mobile RV tech near St Louis. As most, I've had a rig for decades and been in/out of these doing self repair. I have no inside access to the unit in order to check it. With that, where should I start? I hope to find a tech for warranty, however, it's time to get the ball rolling on figuring this out.
Are you saying this thing runs with the breakers off? I'm confused. Access is by removing the cover on the roof. If this smell a new condition?? Has it run correctly in the past?
Thanks,
David
Lynnmor
Red Lion
Posted: 08/07/19 07:02am Link  |  Quote  |  Print  |  Notify Moderator
Now that makes no sense, please explain what breakers you are talking about.
ENG2242
Missouri.
Posted: 08/07/19 09:16am Link  |  Quote  |  Print  |  Notify Moderator
The electric breaker, I smelled electric so I turned off power to it. Makes perfect sense!
ENG2242
Missouri.
Posted: 08/07/19 11:30am Link  |  Quote  |  Print  |  Notify Moderator
Start up capacitor is fried!! Thanks for your help guy's.
