RV.Net Open Roads Forum: Travel Trailers: Battery Disconnect switch
 > Battery Disconnect switch
Npdchief07
Hamilton, Oh
Posted: 08/07/19 11:23am Link  |  Quote  |  Print  |  Notify Moderator
I just bought a Grand Design Transcend. It has a battery connect switch. How does this work? When I am parked in my drive should it be on or off? What about when I am plugged in?
2manytoyz
Central FL
Posted: 08/07/19 11:30am Link  |  Quote  |  Print  |  Notify Moderator
Leave it on when using the camper, connected to shore power, or while towing.
When storing the camper, turn the switch off. This will prevent parasitic (phantom) loads from draining your battery. It's nice yours came with one.
Just sold our TT to our niece this week. I added one of these switches to the battery box since it didn't have one. I also added a solar panel, and charge controller, to the setup. This connects to directly to the battery, which allows charging even when the switch is off.
Robert
Merritt Island, FL
2015 Forest River Georgetown 328TS
2006 Jeep Wrangler Unlimited TOAD
Falcon 2 Towbar, Roadmaster 9400 Even Brake System
http://www.2manytoyz.com/
Lynnmor
Red Lion
It needs to be turned off whenever it is disconnected from tow vehicle or power and not being used. Some trailers have the switch wired in a way that doesn’t disconnect everything and that needs to be checked and corrected.
bob213
Fresno, CA
Posted: 08/07/19 07:54pm Link  |  Quote  |  Print  |  Notify Moderator
Check to make sure that it disconnects everything from the battery. Some leave the CO detector and radio preset connected. These will deplete your battery in a short time.
Abrahamseven38
Fruitland
Posted: 08/08/19 07:00am Link  |  Quote  |  Print  |  Notify Moderator
Are the easy. To install? I like easy.
afidel
Cleveland
Posted: 08/08/19 07:21am Link  |  Quote  |  Print  |  Notify Moderator
Yeah, pretty easy, the biggest trouble with mine was researching to find what size ring terminal was needed and then actually finding them at Home Depot. After that it was: disconnect battery, cut the wire, strip wire, install ring terminals, mount switch, reconnect battery. It couldn't be much easier. I got This style.
2017 KZ Sportsmen Classic 181BH
2015 GMC 1500 Sierra 4x4 5.3 3.42 long bed
E2 WDH
rhagfo
Portland, OR
Posted: 08/08/19 07:35am Link  |  Quote  |  Print  |  Notify Moderator
Yep, that is the style I have also, you may need to get some wire also, but very easy.
wnjj
Cornelius, Oregon
Posted: 08/08/19 09:45am Link  |  Quote  |  Print  |  Notify Moderator
Almost everything. You should leave the trailer brake breakaway switch wired direct to the battery so they will still do their job even with the switch off (like when towing it from storage).
fallsrider
Raleigh, NC
Posted: 08/08/19 01:02pm Link  |  Quote  |  Print  |  Notify Moderator
That's exactly how I installed mine. That way, if I forget to turn the battery switch on while I'm towing, my breakaway system will still work.
