RV.Net Open Roads Forum: Tech Issues: Replacing a propane pigtail
 > Replacing a propane pigtail
waynefi
S E Michigan
Posted: 08/07/19 03:14pm Link  |  Quote  |  Print  |  Notify Moderator
The pigtail to one of my propane tanks has cracks in the hose, so I want to replace it.
When I put in the new one, it flunks the soap bubble test. There are bubbles between the brass fitting on the end of the hose and the brass fitting on the regulator.
The new one’s package reads “RV Thermo Pigtail 1/4” Inverted Flare”.
If I switch back to the old one, it works fine.
Is there some trick to changing these?
Rockwood MiniLite 1809S
Tacoma V6
MDKMDK
Canada
Posted: 08/07/19 03:33pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure. Why not take it to your local Blue Flame or other propane shop and ask them? I've used the BF shop guys before to make up custom hoses and parts for me. They're great.
Mike.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
Old-Biscuit
Verde Valley
Posted: 08/07/19 05:45pm Link  |  Quote  |  Print  |  Notify Moderator
Instead of a 'flared fitting' I would imagine your LP Reg needs an 'Inverter' fitting
BB_TX
McKinney, Texas
Posted: 08/07/19 05:57pm Link  |  Quote  |  Print  |  Notify Moderator
There are at least two different type fittings. Years ago I replaced my high pressure regulator valve and the old pigtail would not fit it. Had to take the fitting from the old regulator and install it on the new one. You might be able to buy an adapter. Check your local well equipped hardware store.
time2roll
Posted: 08/07/19 07:44pm Link  |  Quote  |  Print  |  Notify Moderator
Do the fittings look identical in shape as to the mating surfaces that seal together? That is the replacement hose should look identical to the old hose.
Use no sealant tape right?
I believe most common is the inverted flare but some could be NPT threads.
675w Solar pictures back up
mobeewan
Hampton, Va
Posted: 08/07/19 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
IIRC inverted flare uses straight threads.
I stopped buying pre-made pigtails. Whether they have a pipe thread or reverse flared end both ends of the hose use crimped fittings with barbs. I always had problems with propane leaks between the hose and the fitting. Especially when the hoses got stiff in the winter time and I was switching tanks. The hoses would always rotate a little on the barbs because they were so stiff. I now get my hoses made at a local industrial hose supplier. I took the reverse flare fittings out of the regulator and put in pipe threaded by 45 degree flared elbows and bought green acme nut fittings with male pipe threads on them.
The hoses I have made have a female 45 degree flared swivel on one end and a female pipe thread on the other end. Although they have the same internal diameter, the hoses are a little fatter and the crips are a lot tighter. No more leaks or hoses rotating on the crimped hose barb's.
waynefi
S E Michigan
Posted: 08/07/19 08:20pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, the old and new ones look identical. No sealant tape.
The box the new one came has no instructions at al about screwing it in.
time2roll
Posted: 08/07/19 09:18pm Link  |  Quote  |  Print  |  Notify Moderator
Should not be any trick to it. Snug it up firm and it should seal.
Possible defective.
I recommend Cavagna brand for a superior crimp.
https://www.rvplus.com/lp-gas/pigtails-gas-hoses-and-accessories/pigtails/
Verify part number on page 90
waynefi
S E Michigan
Posted: 08/13/19 09:52am Link  |  Quote  |  Print  |  Notify Moderator
I took the leaky one back and exchanged it for another of the same brand. It also leaked. So I returned that and ordered from Amazon. That one does not leak.
The original, from an RV dealer, cost $30 for one, and leaked. From Amazon, it was $15 for two, and no leak.
dougrainer
Carrolton, Texas
Posted: 08/13/19 10:51am Link  |  Quote  |  Print  |  Notify Moderator
Usually the Pigtails that have a round crimp ring will leak. You want the compressed fitting. The link shows the best crimp. Doug
https://www.walmart.com/ip/Camco-Olympia........_jaeA5AIVSb7ACh1S_QpZEAQYAyABEgJ5hvD_BwE
