RV.Net Open Roads Forum: Tech Issues: Replacing a propane pigtail
 > Replacing a propane pigtail
opnspaces
San Diego Ca
Posted: 08/13/19 11:27am Link  |  Quote  |  Print  |  Notify Moderator
Can you provide the Amazon link for the one that worked for you? I'm thinking about replacing mine.
1996 Suburban 4x4. 350, 4.10 3/4 ton
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
waynefi
S E Michigan
Posted: 08/13/19 07:16pm Link  |  Quote  |  Print  |  Notify Moderator
The one I got is aShinestar 12in RV propane connector.
This is an inverted flare connector. I think that the way you tell them from an NPT is that looking into the end of the connection, the tube walls are beveled, not straight pipe.
On the one I had trouble with, the leak was between the brass on the end of the pigtail and the brass on the regulator.
Rockwood MiniLite 1809S
Tacoma V6
opnspaces
San Diego Ca
Posted: 08/13/19 08:11pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the link, I'll have to look at my hose end the next time the camper comes home.
trailrider
new plymouth, idaho
Posted: 08/13/19 09:40pm Link  |  Quote  |  Print  |  Notify Moderator
Inverted flare trick. Tighten it and loosen it. Repeat a few times and it will seal. Sometimes the initial tightening on a new fitting will leak.
2016 Chevrolet 3500HD
1978 Chevrolet K20 4x4
2007 Komfort 277TS
2020 Sherco 300 SEF Factory
2018 Honda Rancher TRX420FA6
2009 Suzuki DR 650
2017 Montesa 4RT260
