ajriding
st clair
Going electric and removing the propane fridge leaves a big hole in the roof and the side.
Who has closed these up permanently?
I do not see any products out there so assume it is DIY from here on.
DutchmenSport
Indiana
Hopefully you kept the outside covers/vents. If so, close off the inside of the wall, make it water tight, then simply re-insert the original refrigerator vent covers on the outside. No one will notice anything different. But you will know the true story.
Twomed
FL winters and then somewhere cool
AND...if ever need to work on the new fridge you will have some access to back without totally pulling fridge. Had to replace a control board on ours...hole was a big bonus!!!
Happy Trails ">
06 Monaco Dynasty
07 Hummer H3
FMCA 279843
Halmfamily
Munford, AL
I just used foam board insulation to cover the wall holes and then used black Gorilla tape on the inside of the vent covers to cover up the vent holes so bugs couldn't get in.
2008 GMC Sierra 3500 SLT DRW D/A 4x4 (Big All)
2006 Ford F350 PSD SRW King Ranch 4x4 (Henry) (Sold)
B&W Companion, 90 Aux Fuel Tank, Scan Gauge II, Curt f/m hitch, Swagman XC
2015 Forest River Sierra 360 PDEK
DW Diane, DS Michael, FB Draco and Sabian
neschultz
Eastern Shore of MD
I put tape on the back side of our bottom one but left the top alone. If it rained hard from a certain direction, our back one would leak at the gap between the vent and it’s frame so I caulked it with Dap. I did have to open it once after caulking it but it was easy to do ...just used a knife to cut the caulking and then re-caulked later.
Norman & Janet with Minnie the Weiner Dog
2005 SunnyBrook 38 BWQS 5th Wheel (stationary in FL for snowbirding)
Chris Bryant
Arden, North Carolina
Electric refrigerators need ventilation too, depending on condenser location.
-- Chris Bryant
My RV Service Blog
The RV.net Blog
ajriding
st clair
Some RVers will get a chest unit and not use the old frig space, maybe turn it into storage.
The chest unit would sit somewhere else…
PNW_Steve
Pacific Northwet & cold
I have a residential refrigerator with the condenser on the back in my 5er.
I have left the vents open to allow airflow over the condenser. I have done this, with good success, in two rigs and working on my third.
If you close off the outside vents you are going to come up with some sort of ventilation for the condenser.
Good luck.
2004.5 Dodge 3500 5.9 Cummins, NV5400, 5" turbo back stainless exhaust, Edger programmer & 22.5 Alcoa's
2002 Forest River 36 5th Wheel (staying home)
1992 Jayco 29 5th Wheel (Mexico veteran & headed back)
2002 "faux" Wanderlodge 40' My new toy....
neschultz
Eastern Shore of MD
Why, my residential fridge at home doesn’t vent to the outside?
In my case, the condenser is in the bottom and I figured that air would go in at the bottom and out the top and sides, just like in a house.
I have been thinking about closing the top vent though to prevent moisture and outside temps from leaking in. You think that’s a bad idea?
stevemorris
ontario
compressor fridges don't need ventilation they need circulation. all fridges give off heat, a fridge with no ventilation will heat up your trailer, big difference between a 100 sqft trailer vs 1000 sqft house!
2017 Ram 1500 4door, 4x4, 5.7 l hemi, 8 speed
2008 KZ Spree 260
