RV.Net Open Roads Forum: Fifth-Wheels: Ice cream?
 > Ice cream?
Page of 5
camper1013
Twin Cities
Posted: 08/08/19 11:32am Link  |  Quote  |  Print  |  Notify Moderator
I have heard it has to be on the bottom left. Must be the way the coils are that it's colder in that spot. We usually have ice cream along and it has always worked for us.
the bear II
Torrance CA.
Posted: 08/08/19 12:02pm Link  |  Quote  |  Print  |  Notify Moderator
Our Dometic Refrigerator freezer compartment has three zones- the top will freeze anything hard as a rock, the next two shelves will keep frozen food solid but takes a day or so to freeze items not already frozen. The bottom shelf keeps items colder than the refrigerator but rarely will freeze anything.
So we keep ice cream at the top and it stays hard.
It does seem though that some ice cream now days doesn't seem to freeze hard even at home in a residential fridge. We currently have a 3 gallon bucket of ice cream from Kroger that has stayed soft for about two weeks so far. I experienced this with other ice creams as well (usually the cheap stuff).
fj12ryder
Platte City, MO
Posted: 08/08/19 12:58pm Link  |  Quote  |  Print  |  Notify Moderator
That's the carrageenan, and guar gum they put in there to add "body". Good ice cream has neither, but getting harder to find.
That's why the cheap stuff never melts completely, and there's a lump of "stuff" that's left.
Howard and Peggy
"Don't Panic"
pianotuna
Regina, SK, Canada
Posted: 08/08/19 01:01pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
If I understand you correctly, you added a fan in the food part of fridge and not the freezer?
The working medium passes through the freezer first, so adding a fan seems to me to do nada for the freezer. I know it makes no difference in my freezer whether the fan is "on" or "off".
Adding a fan to the "back" (chimney) of the fridge does improve cooling time and freezer operation.
philh wrote:
I added a computer fan inside the fridge. Freezer easily keeps ice cream frozen.
Regards, Don
Allworth
Orlando, FL
Posted: 08/08/19 01:07pm Link  |  Quote  |  Print  |  Notify Moderator
Entrained butterfat!
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Jeeps have round headlights"
Walaby
Georgia
Posted: 08/08/19 05:16pm Link  |  Quote  |  Print  |  Notify Moderator
Guess Im in the minority. My freezer won't freeze 'scream' either.
Freezes everything else quite nicely.
Mike
Im Mike Willoughby, and I approve this message.
2017 Ram 3500 CTD (aka FRAM)
2019 GrandDesign Reflection 367BHS
NRALIFR
Truck Camping Out West
Posted: 08/08/19 05:51pm Link  |  Quote  |  Print  |  Notify Moderator
I almost forgot that not all ice cream is created equal. I only buy Blue Bell at home, because it’s still sold in full half-gallon tubs, and they don’t whip a bunch of air into it before filling them. It freezes hard as a rock if your freezer goes low enough. I don’t even look at all that other phony stuff next to it in the grocery store.
If your favorite brand is sold in three pint containers, it’s not REAL ice cream, and it will always be soft. Every ice cream connie-sewer knows this.
[emoticon][emoticon]
2001 Lance 1121 on a 2016 F450
TXiceman
Full Time RVer
Posted: 08/08/19 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
The coldest spot in most RV fridge is the back lower left hand corner. Keep the carton shoved back in that corner.
Ken
Amateur Radio Operator.
philh
Belleville MI
Posted: 08/08/19 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
Hi,
YMMV... but the fan in the fridge makes the freezer colder. If you think about it, the freezer temperature is heat transfer conduction from the freezer. Pushing the air across the fins not only helps convection, but also conduction... or I'm full of brown stuff and just have a good fridge [emoticon]
Old-Biscuit
Verde Valley
Posted: 08/08/19 10:28pm Link  |  Quote  |  Print  |  Notify Moderator
philh wrote:
pianotuna wrote:
Hi,
Freezer and food compartment are completely separate...no connection between the two compartments
Freezer Low Temp Evap Coil gets the coldest ammonia to absorb the heat from freezer THEN that ammonia tries to absorb heat from food compartment.
The colder the freezer gets the more capacity the ammonia will have to absorb heat from food compartment
Freezer temp will affect food compartment temp.....food compartment temp does not affect freezer temp
Warm food compartment temp will cause thermostat to turn heat source on more frequently which in affect will cause freezer to get colder EVEN if food compartment does not get colder...
Fan circulating the cool air inside the food compartment helps to even out the overall temp in food compartment regardless of freezer temp
Page of 5
 > Ice cream?
