RV.Net Open Roads Forum: Travel Trailers: Towing a Geo Pro 19bh
 > Towing a Geo Pro 19bh
jordan2110
abbotsford
Posted: 08/07/19 09:34pm Link  |  Quote  |  Print  |  Notify Moderator
Anyone know if I'd be ok towing a Geo Pro 19bh with a 2019 Jeep Grand Cherokee 4x4 with 3.6L engine.
Trailer spec..
Hitch Weight 360 lbs
Gross Weight 3860 lbs
Dry Weight 3088 lbs
Cargo Weight 772 lbs
jeep towing capacity 6200lbs. I feel I will be ok and I'll add a WDH. Thanks
Morro Bay, CA
Posted: 08/07/19 09:39pm Link  |  Quote  |  Print  |  Notify Moderator
Could be. What’s the Jeep’s payload and max trailer weight? Who and what will be in the Jeep? PS...a WDH is a good idea but it doesn’t increase max trailer weight and it uses about 75 pounds of payload. Your hitch weight is a dry weight. Loaded/wet it’ll be more....500 pounds or so and that comes off your payload.
Morro Bay, CA
Posted: 08/07/19 09:47pm Link  |  Quote  |  Print  |  Notify Moderator
I wouldn’t advise a single axel TT but others are ok with them. 772 pounds for trailer cargo of which 305 will be taken by fresh water. Better pack light...no bikes, firewood etc.
afidel
Cleveland
Posted: 08/07/19 11:11pm Link  |  Quote  |  Print  |  Notify Moderator
If the GC isn't full of people you'll probably be ok, but you certainly won't win any races up steep grades but it should get you there.
2017 KZ Sportsmen Classic 181BH
2015 GMC 1500 Sierra 4x4 5.3 3.42 long bed
E2 WDH
GrandpaKip
Flat Rock
Posted: 08/08/19 06:45am Link  |  Quote  |  Print  |  Notify Moderator
You will have about 500 pounds on the tongue and maybe more. Subtract that from the payload of the Jeep and see what you’ve got left for passengers and cargo in it.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
jordan2110
abbotsford
Posted: 08/08/19 07:08pm Link  |  Quote  |  Print  |  Notify Moderator
So the Jeep has
Curb 4,965 Lbs.
Gross weight 6,500 Lbs.
So I calculate 1535 Lbs payload available.
4 Passengers = 420lbs
Tongue= 500lbs
Luggage/camping gear/kids **** = max 150lbs
So that equals 1070 lbs.
So it seems ok. Did I do my calculations correct.
Morro Bay, CA
Posted: 08/08/19 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
OP MIA cuzz he didn’t hear what he wanted to hear?
afidel
Cleveland
Posted: 08/08/19 11:45pm Link  |  Quote  |  Print  |  Notify Moderator
Yep, sounds good. Even plenty of room for kids to get bigger =)
Jebby14
Windsor Ontario
Posted: 08/09/19 04:02am Link  |  Quote  |  Print  |  Notify Moderator
should be ok. don't forget the weight of the hitch though (around 100 lbs)
If it moves and it shouldn't..... duct tape
if it doesn't move and it should.....WD40
if all else fails .....BFH
GrandpaKip
Flat Rock
Posted: 08/09/19 07:28am Link  |  Quote  |  Print  |  Notify Moderator
The yellow tire placard on the door of your Jeep should give you the cargo capacity.
Sounds as if the Jeep will be fine for what you want to do.
