RV.Net Open Roads Forum: Tech Issues: Battery Storage Scenario
 > Battery Storage Scenario
SweetLou
La Quinta, CA USA
Posted: 08/08/19 07:45am Link  |  Quote  |  Print  |  Notify Moderator
If I store new fully charged batteries in my shop for 6 mo through winter where the shop could be as cold as 10-15 degrees, would they be all right for next season? Or, should I use my harbor Freight battery maintainers to keep them up? They are cheap and there would be no one around to check them for the 6 months
2013 3500 Cummins 6.7 Quadcab 4x4 3.73 68FE Trans, 2007 HitchHiker Discover America 329 RSB
We love our Westie
SidecarFlip
SE Michigan
Posted: 08/08/19 08:02am Link  |  Quote  |  Print  |  Notify Moderator
If it's a flooded cell battery and it's fully charged when put in storage, there is no reason to trickle charge it. It will hole most of it's charge over the winter. I do that all the time with my farm tractors. I leave the start batteries in them but break the negative side with a knife switch. They start fine in the spring and it gets cold here.
What people don't realize is it's HOT weather that destroys a battery, not cold weather but the reason batteries fail in cold weather is because the battery was already compromised that summer but when it's cold, it takes appreciably more cold cranking amps to turn the engine and the compromised battery cannot supply them.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
pianotuna
Regina, SK, Canada
Posted: 08/08/19 09:23am Link  |  Quote  |  Print  |  Notify Moderator
The cooler the temperature the less self discharge.
I would place a maintainer on the jars for 24 hours once per month.
Regards, Don
Sandia Man
Rio Rancho, NM
Posted: 08/08/19 09:34am Link  |  Quote  |  Print  |  Notify Moderator
As long as they are fully charged they will be fine whether in your shop, garage, or on your rig. Our RV is parked in our side yard always connected to shore power, we keep it simple and just leave our batteries in place all year long, harsh winters and blazing summers have little effect on our fully charged batteries.
profdant139
Posted: 08/08/19 10:00am Link  |  Quote  |  Print  |  Notify Moderator
Is there a good reason not to use a trickle charger? Maybe I am missing something. I keep my batteries on one of those BatteryMinder Plus things -- supposedly, they pulse and keep the battery from sulphating. But I have also heard that this is a hoax and accomplishes nothing more than an ordinary trickle charger would do.
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 08/08/19 10:34am Link  |  Quote  |  Print  |  Notify Moderator
The 10-15 degrees would be a small, make that tiny, percentage of the total time. Although not mandatory a temperature compensated maintenance charger would pay for itself by extending battery life.
schlep1967
Harrisburg, PA
Posted: 08/08/19 10:35am Link  |  Quote  |  Print  |  Notify Moderator
If I were going to hook my $100+ battery to a charger/maintainer ..... it wouldn't be a $10 Harbor Freight version.
You can get several different brands of decent quality for around $30. I have this one I use on my motorcycle that cost $50 Charger/Maintainer
Those $10 Harbor freight models will not charge a battery if it is under 9 volts. The extra money for the one I linked will charge a battery from dead. It brought both of my batteries on my diesel truck back overnight when I killed them by leaving the switch on.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
schlep1967
Harrisburg, PA
Posted: 08/08/19 10:39am Link  |  Quote  |  Print  |  Notify Moderator
Just curious, why would you buy new batteries in the fall if you are not going to use them all winter? Just wait and buy new batteries in the spring.
RJsfishin
Winston Or.
Posted: 08/08/19 11:49am Link  |  Quote  |  Print  |  Notify Moderator
Surely you can come up w/ a better reason than that for bad mouthing a 1 amp charger. Who would want to connect a 1 amp maintainer to a battery discharged to 9 volts anyway ?? Fer a 5 dollar bill I have found them to be quite reliable.
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
SweetLou
La Quinta, CA USA
Posted: 08/08/19 12:05pm Link  |  Quote  |  Print  |  Notify Moderator
Needed replacing this past spring so virtually new
