RV.Net Open Roads Forum: Tech Issues: A/C on 116 volts?
 > A/C on 116 volts?
NEOK
Oklahoma
Posted: 08/08/19 03:24pm Link  |  Quote  |  Print  |  Notify Moderator
I just pulled into a site and EMS only shows 116 volts. Would you trust it to run 10,500btu AC unit for one night without doing damage go the unit?
Thanks
neok
2009 GMC 25000HD Short Bed 6.0 Gas Engine Crew Cab SLT 4x4
2008 Bigfoot 15C9.5FS
Torklift Talons, Fastguns, Stableload Quick Disconnects, Superhitch & SuperTruss
theoldwizard1
SE MI
Posted: 08/08/19 03:27pm Link  |  Quote  |  Print  |  Notify Moderator
That is well within the specifications in the US, as long as it does not drop to far when the AC is starting.
rk911
Wheaton IL
Posted: 08/08/19 03:28pm Link  |  Quote  |  Print  |  Notify Moderator
I would, yes. 120-volts +/- 10% (108-132).
Rich
Ham Radio, Sport Pilot
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
LittleBill
Scranton, PA USA
Posted: 08/08/19 03:38pm Link  |  Quote  |  Print  |  Notify Moderator
108v and higher and your good while running
vermilye
Oswego, NY, USA
Posted: 08/08/19 03:47pm Link  |  Quote  |  Print  |  Notify Moderator
is the important point. If you see 108V with the compressor off, it will likely drop below that when it starts & runs.
Jon Vermilye My Travel Blog
My Photo & RV link blog
NEOK
Oklahoma
Posted: 08/08/19 03:53pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks to everyone for the quick replies.
Neok
Wherever I happen to park
Posted: 08/08/19 04:33pm Link  |  Quote  |  Print  |  Notify Moderator
Second I'd have no probems with 116.
IN my life standard household voltage was first called 110 (and 220)
Then it became 115/230 and now 120/240
116 is meter error off dead center in that range (115)
Home is where I park it.
LadyRVer
Posted: 08/08/19 04:54pm Link  |  Quote  |  Print  |  Notify Moderator
Don't like to, but if it hits 105, I switch refrig to LP and that helps a little.
Agree with the other posters. I don't panic at 108-110.. but don't like it in that range.
pianotuna
Regina, SK, Canada
Posted: 08/08/19 06:11pm Link  |  Quote  |  Print  |  Notify Moderator
There are autoformers that can deal with low voltage.
Regards, Don
myredracer
Langley B.C.
Posted: 08/08/19 06:56pm Link  |  Quote  |  Print  |  Notify Moderator
To add to the above, it's a good idea to have a permanently mounted LED voltmeter inside. Voltage can often fluctuate over 24 hours, depending on how many other occupied sites there are and how many are running AC units. Other RV-ers can also drag the voltage down around lunch and dinner time due to some folks using electric appliances in addition to AC units.
If you see voltage at around 110 you may want to keep an eye on it. If it gets below 105, that's when it can cause damage to AC units.
If you do encounter low voltage, as mentioned, an autoformer may keep you going when you'd otherwise have to shut the AC off. An EMS unit is a good investment as it will automatically shut you down on low voltage.
Gil, Deb & Dougal a 15 year old Springer Spaniel
2014 KZ Spree 262RKS, Reese DC WDH, shocks and Endurance LRE tires
2012 GMC Sierra 2500HD crew cab, Bilstein shocks, heavy duty trailering option
 > A/C on 116 volts?
