RV.Net Open Roads Forum: Tech Issues: Portable Solar Smoking
 > Portable Solar Smoking
Grodyman
Enemy Territory
Posted: 08/08/19 05:07pm Link  |  Quote  |  Print  |  Notify Moderator
I inherited a NaturePower 120 Watt suitcase solar kit. Opened it up and hooked alligator clips to terminals of battery, after a short time, smoke coming from the wiring/charge controller area behind the solar panel.
What could cause this? Wire run was maybe 6 feet.
Gman
2017 F150 CC/5.5' 4x4 3.5 Ecoboost/3.55
2018 Passport Ultra-Lite 153ML
BFL13
Victoria, BC
Posted: 08/08/19 05:48pm Link  |  Quote  |  Print  |  Notify Moderator
Reversed polarity?
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
Grodyman
Enemy Territory
Posted: 08/08/19 06:08pm Link  |  Quote  |  Print  |  Notify Moderator
BFL13 wrote:
Reversed polarity?
Maybe, if the red and black wires are mixed up from the factory.
Also, no current going into the battery was registering on my battery monitor.
Johnny G1
Clearwater, British Columbia ,Canada
Posted: 08/08/19 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
Should have hooked up controller first before opening suit case possible blown controller, controller need's battery power first. Foud that the hard way when a battery went out and fried a $3oo controller, no where for power to go from panel's. Possible reversed cable's????
98 Mountain Aire 34' 210 Cummins Puller and 2001 dodge dully with all the toy's, 400 + hp pullin a 28' 5th wheel Travel Aire. Lots of fun.
Grodyman
Enemy Territory
Posted: 08/08/19 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
Not reverse polarity. Interesting about the controller needing battery before opening panel. I wasn't aware of that. It is a cheap plastic controller, garbage.
naturist
Lynchburg, VA
Posted: 08/08/19 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
Probably is garbage now. Controller must be hooked to battery before any solar. Usually that’s taken care of by hooking controller to battery, THEN hooking panels to controller. Shut down by disconnecting panels THEN disconnecting battery. Since panels produce a small amount of power even in dim light, there’s no room for error. If there’s smoke, something is burnt up.
BFL13
Victoria, BC
Posted: 08/08/19 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
With a "kit" the panels are already wired to the controller's array side, so all you can do is connect the controller's battery side to the battery. This should not fry that controller.
Some controllers, not all, will go bad if you do not follow the proper sequence in their user manuals--connect battery first then array, and VV when disconnecting.
Must be something else the matter. Take it all apart and check each panel aimed at the sun using your DMM to make sure each one is ok (see their Isc and Voc specs), then re-assemble and try again.
Vintage465
Prunedale CA.
Posted: 08/08/19 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
This is great info. I'm planning to get a 300w suitcase type unit with controller to supplement my 300w on the roof if we get in a shady place. Who knows what order I may have hooked it up in. Good info for sure.
Thanks,
V-465
2013 GMC 2500HD Duramax Denali. 2015 CreekSide 20fq w/450 watts solar and 465 amp/hour of batteries. Retiring in 2021, then look-out road, here we come!
Vintage465
Prunedale CA.
Posted: 08/08/19 06:56pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks,
Grodyman
Enemy Territory
Posted: 08/08/19 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
Controller is connected to rear of panel, so I would need to connect the clips while keeping the suitcase covered from the sun, then open the panels to the sun after connecting.....Is this the standard procedure?
