RV.Net Open Roads Forum: Tech Issues: Portable Solar Smoking
 > Portable Solar Smoking
Mojave, Kern County, California
Posted: 08/08/19 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
Must be fun setting that up each morning. Unless you go to town for lunch. Then you get to set it up after lunch too.
naturist
Lynchburg, VA
Posted: 08/08/19 08:35pm Link  |  Quote  |  Print  |  Notify Moderator
Grodyman wrote:
Controller is connected to rear of panel, so I would need to connect the clips while keeping the suitcase covered from the sun, then open the panels to the sun after connecting.....Is this the standard procedure?
Yup.
rexlion
Broken Arrow OK
Posted: 08/08/19 08:53pm Link  |  Quote  |  Print  |  Notify Moderator
And here I thought this would be about how to smoke meat using a solar powered smoker........
Mike G.
--for now, using a cargo trailer for camping--
Those who would give up essential liberty, to purchase a little temporary safety, deserve neither liberty nor safety. --Benjamin Franklin
photo: Yosemite Valley view from Taft Point
gemsworld
Arizona West Coast
Posted: 08/08/19 08:54pm Link  |  Quote  |  Print  |  Notify Moderator
I used a 120 watt suitcase kit with the controller attached to the back of one panel for years and I connected the batteries to the controller after I had the panels set up. I never had a problem and never heard anyone mention having to hook up the batteries before the panels were exposed to sunlight.
Grodyman
Posted: 08/08/19 09:02pm Link  |  Quote  |  Print  |  Notify Moderator
Instructions don't mention this either, just says plug into port or connect to batteries. I'll buy a cheap controller and try again.
2017 F150 CC/5.5' 4x4 3.5 Ecoboost/3.55
2018 Passport Ultra-Lite 153ML
naturist
Lynchburg, VA
Posted: 08/09/19 05:06am Link  |  Quote  |  Print  |  Notify Moderator
If the instructions didn’t mention the battery first thing, that controller would have to not care, as I’m sure many purchasers would open then connect. All the controllers I’ve seen do proclaim battery first, but obviously I haven’t seen ‘em all. Still, smoking wires are always a bad sign.
Sandia Man
Rio Rancho, NM
Posted: 08/09/19 08:33am Link  |  Quote  |  Print  |  Notify Moderator
Although that may occur to some solar controllers, the one that came with our Renogy solar suitcase does not have this issue. There is no way you can connect the portable solar panel to your battery without prior exposure to the sun, our unit comes in a padded black case and the second you unzip it both panels are fully exposed.
Just start with a new controller, water proof would be better as I lost one to a passing flash storm common here in the Mountain West. Since you inherited it double check wiring before connecting new controller in case it has been fiddled with. I find our portable panel can really keep up with what we already have on the roof being that we can reposition it a few times a day maximizing periods of peak output.
