RV.Net Open Roads Forum: Anyone Make a 2-Tank Regulator that is Not Auto-Changeover?
 > Anyone Make a 2-Tank Regulator that is Not Auto-Changeover?
troubledwaters
Potomac
Posted: 08/09/19 05:24am Link  |  Quote  |  Print  |  Notify Moderator
Buying a regulator and tee valve will cost just as much or more then the auto changeover regulator. Just buy a direct replacement auto change over regulator and use it like you have been.
SoundGuy
S Ontario
Posted: 08/09/19 08:22am Link  |  Quote  |  Print  |  Notify Moderator
X2!! No need to make this any more complicated - K.I.S.S. and simply replace the aged auto changeover regulator with another and be done with it. The OP isn't alone, many of us choose to run our regulator manually, running just one tank at a time 'til it empties then manually switching to the second tank. Not once have I ever had to get up in the middle of a cold, rainy night to switch the regulator over to the second tank. And so what if it did ever happen, it's not like death is on your doorstep if you do go outside! [emoticon]
2012 Silverado 1500 Crew Cab
2014 Coachmen Freedom Express 192RBS
2003 Fleetwood Yuma * 2008 K-Z Spree 240BH-LX
2007 TrailCruiser C21RBH * 2000 Fleetwood Santa Fe
1998 Jayco 10UD * 1969 Coleman CT380
D.E.Bishop
Eagle Rock, CA
Posted: 08/09/19 08:39am Link  |  Quote  |  Print  |  Notify Moderator
Check here and then order from your local dealer.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
Back to a 2006 Suzi GV
Roadmaster 5000
Roadmaster Invisibrake
Woodtroll
Appalachian Mtns, SW Virginia
Posted: 08/09/19 10:49am Link  |  Quote  |  Print  |  Notify Moderator
Exactly; I’ll take that risk! [emoticon]
Thanks again, everyone.
2003 F250XL 4WD 7.3L Crewcab LB, 6 speed; Prodigy brake controller; Big Tex grille guard/ deer deflector. Canoe hauler and camping truck extraordinaire!
2003 Layton 242 Scout- Extra batteries, solar panels, LED lighting, and propane for boondocking.
BFL13
Victoria, BC
Posted: 08/09/19 01:18pm Link  |  Quote  |  Print  |  Notify Moderator
Except for bears and cougars [emoticon] Send your dog out first!
https://www.goldstreamgazette.com/news/b........unches-bear-in-a-northern-b-c-encounter/
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
Woodtroll
Posted: 08/09/19 01:32pm Link  |  Quote  |  Print  |  Notify Moderator
Haha! Yes indeed, some places are riskier than others. We do have an increasing population of black bears that cause nuisance problems in many of the places we stay, but the most persistent animal problem we usually face is entitled raccoons that believe they should have access to our locked wooden food box! They get kind of grouchy when they can't get in, amd sometimes tear up things in apparent spite. [emoticon]
There are rumors of mountain lions here in the Eastern Appalachians, but no proven populations.
Safe camping, sir, and thanks again!
time2roll
Posted: 08/09/19 11:53pm Link  |  Quote  |  Print  |  Notify Moderator
Any automatic regulator will run fine with either cylinder turned off. No need for something special.
I recommend Cavagna brand regulator and pigtails if spending money.
675w Solar pictures back up
JRscooby
Indepmo
Posted: 08/10/19 05:30am Link  |  Quote  |  Print  |  Notify Moderator
I would thing any good regulator with a tee on the input side would do what you want. Just close the valve on the MT tank before open the full.
My Dad liked the auto change, but had a issue with his old camper. When the valve switched, the fridge would go out sometimes. He decided that while the tank was off being filled air would get in the line. When air bubble got to fridge, food warms. He put a tee in just ahead of regulator and a small valve to outside. Hook up fresh filled tank, close valve on other, open the new, then the little valve for just a second or 2. Open valve on the other tank, make sure drawing from the right one...
wopachop
lb
Posted: 08/10/19 07:52am Link  |  Quote  |  Print  |  Notify Moderator
I have a buddy who is very mechanically inclined and has owned trailers for at least 20 years. He noticed a slight propane smell from my trailer and told me the auto regulators are known to leak unless you keep both tank valves open.
We didnt discuss different brands. Was just a quick tip he told me.
Actually as im thinking back now i can remember if he said both HOSES need to be attached.....or if both tank valves need to be open.
