RV.Net Open Roads Forum: ONAN 5500 Grand Marquis fuel pump & filter
 > ONAN 5500 Grand Marquis fuel pump & filter
drifterpilot
Gloucester, Virginia
Posted: 08/08/19 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
I have the Onan 5500 Grand Marquis generator on my motorhome.
Model# 5 . 5 H G J A B - 1 0 8 C
I want to replace the inline electrical fuel pump and filter on the generator.
The part number on the fuel pump is Cummings A O 2 9 F 8 8 7. This number has been discontinued.
Does anyone have good part numbers for these two items?
Cummings or other after market part numbers??
I could use a part number for the carburetor also.
Thank you.
2003 Winnebago Adventurer 33V
112,000 miles
Workhorse W20
Vortec 8.1, Allison 1000
Kingdome (in-motion tracking)
Bilstein shocks (installed July 2013)
Safe-T-Plus Steering Stabilizer
Blue Ox Adventa II and KarGuard
Brake Buddy
2019 Chevrolet Colorado LT 4-Wheel Dr
ArchHoagland
Clovis, CA, USA
Posted: 08/08/19 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
I'm curious why you are changing them.
What kind of problem are you seeing and also how many hours are on the generator.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
GREGORYJ
Lac Du Bonnet, Manitoba
Posted: 08/08/19 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
I got a fuel pump and filter off Amazon.com a few years ago and is still working fine. My fuel would stop(seize) when it got hot causing generator to stop. It
would work again once it cooled but stop again when hot. In cold weather it would work better.
https://www.amazon.com/s?k=onan+5500+fuel+pump&crid=VQGILPQ11T1L&sprefix=onan+%2Caps%2C286&ref=nb_sb_ss_i_4_5
Ellen & Greg
08 National Dolphin DL-35Ci, Kelderman Air Ride, Rear Trac Bar
Workhorse W22, RoadMaster Rear Sway Bar, Towing 08 Smart Car
MountainAir05
New Mexico
Posted: 08/08/19 09:22pm Link  |  Quote  |  Print  |  Notify Moderator
just about any pump will work. Just keep the pressure out put low. Its either 3 or 5 lbs max. Sure someone will jump in .
This is what I got many years ago when I needed one right now. Been working since.
https://www.amazon.com/Bravex-Universal-Pressure-Electric-HEP-02A/dp/B01NA6AEXC
* This post was edited 08/08/19 09:31pm by MountainAir05 *
IB853347201
Eastern Ontario
Posted: 08/09/19 06:21am Link  |  Quote  |  Print  |  Notify Moderator
Just Google "fuel pump for marquis gold 5500 gasoline/hgjab", and several links will come up including Amazon.com which lists replacements starting at just over $20.
Same for the carburetor. Amazon lists Cummins 5410765 Onan Carburetor Kit as the replacement.
Touring in our 2010 Suncruiser, beaches, site seeing, national parks, chillaxing..
apr67
Tallahassee, Florida
Posted: 08/09/19 07:25am Link  |  Quote  |  Print  |  Notify Moderator
You can get the OEM Onan one from PPl motorhomes for $82. I bought the Airex from Amazon. Mine failed after 40 days, in the same way as yours is currently failed, overheats after a few hours and then if it cools it works again. Tried to use the warranty, well their is no warranty, because the warranty has to be honored by the seller and Amazon won't take it back after 30 days.
They also have the fuel filter.
https://www.pplmotorhomes.com/parts/rv-appliances/generator/permanent-generators/permanent-generator-replacement-parts/cummins-onan-fuel-pump-a047n929_49-7991?gclid=EAIaIQobChMI2YqipvH14wIVmpOzCh3YuwywEAQYBCABEgIoKPD_BwE
https://www.pplmotorhomes.com/parts/rv-appliances/generator/permanent-generators/permanent-generator-replacement-parts/onan-fuel-filter-149-2341-01_68657
2017 Thor Hurricane 34J
Gone-2014 Chevy Express 3500
Gone-2016 Jayco White Hawk 32DSBH
Gone-2013 Keystone Bullet 294BHS
Gone-2007 National SurfSide 34DE
Gone-2006 ForestRiver Sunseeker 2900LTD
Gone-1994 Fleetwood PaceArrow
Gone-1978 Kit RoadRanger
2manytoyz
Central FL
Posted: 08/09/19 09:23am Link  |  Quote  |  Print  |  Notify Moderator
I posted a video on YouTube where I replaced the fuel pump and filter on mine.
https://www.youtube.com/watch?v=nyHNPczC2YQ
I bought the replacement pump ($34.95) and fuel filter ($17.48) on Amazon.
Fuel pump: https://amzn.to/2UZjVRt
Fuel filter: https://amzn.to/2GxDSM7
Pretty easy job. Watch the video first if you're unsure.
Robert
Merritt Island, FL
2015 Forest River Georgetown 328TS
2006 Jeep Wrangler Unlimited TOAD
Falcon 2 Towbar, Roadmaster 9400 Even Brake System
http://www.2manytoyz.com/
