RV.Net Open Roads Forum: Fifth-Wheels: Slide out awnings
 > Slide out awnings
CaLBaR
Ontario, Canada
Posted: 08/10/19 05:23am Link  |  Quote  |  Print  |  Notify Moderator
Recently put one on my new trailer. Loved the one on the last one and love this one. I wish I could put on on the second slide but the awing would interfere. For all the reasons mentioned above I will always have them.
2018 Grand Design Reflection 297RSTS
2019 RAM 3500 SRW Big Horn 4x4, 6.7 Cummins/Aisin
2007 Rockwood 8298 SS (Traded in 2018)
2009 Toyota Tundra 4x4 Crew Max 5.7L (Traded in 2019)
HP Dual Cam Sway Control
Prodigy Brake Controller
Walaby
Georgia
Posted: 08/10/19 06:05am Link  |  Quote  |  Print  |  Notify Moderator
I installed mine myself. Love them.
CaLBaR - You can install them on the slide with the awning. I did it. Several threads discussing this on the GrandDesign RV forum.
Mike
Im Mike Willoughby, and I approve this message.
2017 Ram 3500 CTD (aka FRAM)
2019 GrandDesign Reflection 367BHS
CaLBaR
Ontario, Canada
Posted: 08/10/19 12:12pm Link  |  Quote  |  Print  |  Notify Moderator
Mike
Thanks Mike. I am a member on the GD forum as well. I guess I should be more clear that my awning goes over the top of the slide out and is not attached to the side. Not enough room when the awning goes out or under the awning to put one on or so it seems. Maybe you have pictures if yours is like mine.
Rob
Pine Barren
Northwest Florida
Posted: 08/10/19 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
Yes for all the reasons previously stated. I did however take the big swim noodles and use them to slide under the topper when it rains to help let the water run off and not cause it to sage in a bad down pour. The reason I did this was because I was in a bad downpour and the awnings sages enough to cause the water to run off on top of slide .
Walaby
Georgia
Posted: 08/10/19 08:48pm Link  |  Quote  |  Print  |  Notify Moderator
Mike
Rob
Aha... No, mine's not like yours.
I could see that being a problem.
Interesting setup. Not sure I've seen that before.
Mike
CaLBaR
Ontario, Canada
Posted: 08/11/19 05:10am Link  |  Quote  |  Print  |  Notify Moderator
Walaby wrote:
Mike
Rob
Mike
Yes pretty much like everything about our trailer but they really should have put 2 awnings on it with one on the slideout like what you have. Other models have that just not sure why they did this one this way.
Rob
ACZL
UPstate,NY
Posted: 08/11/19 08:16am Link  |  Quote  |  Print  |  Notify Moderator
How do swim noodles help? Being they are so small in diameter, don't see how they can be effective. Plus, how do you get them onto the tops of the slides? Have seen a thread or 2 where folks put blow up beach balls under the toppers so rain doesn't sag them, but same question....how do you get them between the topper and slide and out? Plus, it would seem to me that one would need a tall ladder to do this, especially the front ones.
FWIW, we have the slide-n-slide and toppers are on everything and love them. Have seen some mfr's where the toppers actually have a angle on them due to them being attached higher than slide where some are more/less at same angle w/o much of a tilt for water to run off...thus the sag.
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
Braces
Alabama
Posted: 08/11/19 09:46pm Link  |  Quote  |  Print  |  Notify Moderator
YES
ependydad
Here and there
Posted: 08/12/19 09:13am Link  |  Quote  |  Print  |  Notify Moderator
They’re a yes for me, but there are pros and cons:
https://learntorv.com/slide-toppers-aka-awnings-definitely/
2017 Spartan 1245 by Prime Time
2018 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: TrailerSaver TS3
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
laknox
Arizona
Posted: 08/12/19 09:22am Link  |  Quote  |  Print  |  Notify Moderator
Saw a DIY article about a guy who was having issues with his in-slide fridge cooling well. He cut some plywood that fits over the slide "flange" that allows him to put a rod in a groove on the plywood and holds a simple tarp. Stakes the lower end of the tarp down to provide shade over the fridge slide. Said it made a huge difference in how his fridge cooled. IIRC was in Trailer Life a few months ago.
Lyle
* This post was edited 08/12/19 11:37am by laknox *
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 62 Year Member
 > Slide out awnings
