RV.Net Open Roads Forum: Tech Issues: refrigerator iceing up
 > refrigerator iceing up
badboy368
OHIO
Posted: 08/09/19 02:40am Link  |  Quote  |  Print  |  Notify Moderator
I have a Norcold model 1200 series fridge, and all of sudden the fins in the fridge part are iceing up. I completely defrosted it and put in a fridge fan.....still iceing up. Anyone have any ideas why? or what I should do?
40' pusher,350 turbo cat, pullin a 37' trailer haulin a drag car. oh yea baby
rjsurfer
North Carolina
Posted: 08/09/19 02:59am Link  |  Quote  |  Print  |  Notify Moderator
Leaky door seal?..You could be getting warm air and humidity bypassing a seal somewhere.
Ron W
03 Dodge 2500 SRW,SB,EC
2018 Keystone 25RES
DRZ-400SM
DL-650
cavie
Posted: 08/09/19 06:30am Link  |  Quote  |  Print  |  Notify Moderator
youtube is your friend.
https://www.youtube.com/watch?v=e3K0fQxqiuc
rrupert
NW PA
Posted: 08/09/19 06:45am Link  |  Quote  |  Print  |  Notify Moderator
Some late model fridges have a mode programmed in that shuts them off occasionally to allow the fins to warm up and melt the ice buildup. Our Norcold does that.
Rich and Joyce
2018 Jayco Jay Flight 21QB
2012 Ford F150 4X4 Supercrew EcoBoost
Reese Strait-Line Dual Cam Hitch
Amateur Radio K3EXU
Old-Biscuit
Verde Valley
Posted: 08/09/19 09:00am Link  |  Quote  |  Print  |  Notify Moderator
IS the Temp LED Flashing?
Bad thermistor
Door seals...leaking warm air into fridge
Drip tray drain hose not in a little water in cup next to burner...warm air coming back up drain hose
1492
Arlington, VA
Posted: 08/10/19 11:27pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from Forum Posting Help and Support
Scottiemom
South Dakota/Indiana
Posted: 08/11/19 04:31am Link  |  Quote  |  Print  |  Notify Moderator
Open the left fridge door. At the inside top of door, there are 3 pins. Those pins should all be in the same position and when closed, touch the round discs on the inside box of the fridge. If they are not perfectly aligned, icing will occur. Our door had sagged a bit and one pin had actually caused scorching on the round disc. Leon at National Refrigeration in Shipshewana made an adjustment and it's been working property ever since.
Dale
Dale Pace
Wife to Terry (Teacher's Pet)
2006 Tiffin Phaeton 40'(Phaeton Place)
2014 Ford Flex
2004 R-Vision Trail-lite 213 (MinnieMee)
Fulltiming since 2005
http://www.skoolzoutforever.blogspot.com/
Where are we?
badboy368
OHIO
Posted: 08/11/19 09:31am Link  |  Quote  |  Print  |  Notify Moderator
Thank You for the tips. I will check all of these, and hopefully solve the problem.
dougrainer
Carrolton, Texas
Posted: 08/11/19 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
Icing can only happen from the Humidity in the air inside the refer. Icing is usually normal. The fins will be 10 degrees COLDER than the inside temp of the items in the refer. HOW thick is the ice? Norcolds have a built in defrost feature for this type problem. The feature ONLY works when the refer stays ON continuously for more than 60 hours. Every 48 to 54 hours, the Norcold refer shuts OFF for 2 to 3 hours. This allows the fins to warm up and the ice to melt and drain outside to the drip cup. If you turn the refer OFF and then ON during that 60 hours, the timer starts over again. You could have the evap pan drain tube check valve not installed and that allows air back up to the evap fins. You can have a bad seal on the refer door allowing air inside. I have also had refers where the customer installed items in the refer that pushed against the closed doors and this caused the door to have a slight gap that went past the door seal. Doug
badboy368
OHIO
Posted: 08/12/19 02:17am Link  |  Quote  |  Print  |  Notify Moderator
Very good tips Doug.....Thank YOU
