RV.Net Open Roads Forum: Why not forget holding tanks and just use portable tanks?
 > Why not forget holding tanks and just use portable tanks?
Page of 5
nicpaige
Ohio
Posted: 08/09/19 11:39am Link  |  Quote  |  Print  |  Notify Moderator
I have an all aluminum trailer that I am turning into a toy hauler. The floor framing is 12" on center and I beam construction. This only leaves 8-9" width to fit the tanks in between the rails. For any kind of volume the tank would have to be quite tall. I do not want my storage tanks 7" from the road for obvious reasons. So......
Is it just craziness to think about running the drains to the waste valves and straight into those portable tanks you can roll to the dump station? I realize I would need one for grey and one for the black tank.
What am I missing in this process? Or is it feasible and been done before?
Thanks,
Rick
the bear II
Torrance CA.
Posted: 08/09/19 11:50am Link  |  Quote  |  Print  |  Notify Moderator
That would work for most boondocking areas but most RV, National and state parks require RVs to meet RVIA standards which include holding tanks. You'll see park rules state "Must be fully self contained"
Recreation Vehicle Industry Association (RVIA)
Those blue portable tanks can be a hand full to dump depending on where you have to dump them. The smell can be deadly.
Holding tanks with a sealed sewer hose setup is the best way to go. Little or no smell or mess.
myredracer
Langley B.C.
Posted: 08/09/19 11:57am Link  |  Quote  |  Print  |  Notify Moderator
Thanks,
Rick
Never heard of it before. Filling and dragging tote tanks to wherever the dump station is (and they can sometimes be far from your site) is a big PITA. And the larger the tote tank is, the more of a PITA to use. We have a smaller 18 gallon one that both DW and I can lift into the truck if needed. Not that they ever work well, or at all, but you obviously won't have sensors in a tote tank to tell how full the tank is.
I assume you've looked into what's available in standard RV holding tank dimensions like here for example? Narrowest is 11" wide but only up to 25 gallons. They have a 7.75" wide 32 gallon one but is 21.5" tall. [emoticon] Would it be possible to relocate the joists to gain more width? Possibly double up the joists on either side, providing the sub-floor is thick enough?
I would say 32 gallons is about as small as you want to go for holding tanks, for a black tank anyway so you're not running to the dump station every 2 or 3 days.
A macerator pump *might* be an option but would still need a holding tank for the pump to pump out of. Could maybe get away with a small holding tank that way?? Then pump into a tank in the back of your truck?? Maybe you could be the honey wagon service in a CG that way and make a few bucks! [emoticon]
Interesting comment above about RVIA requirement!
Gil, Deb & Dougal a 15 year old Springer Spaniel
2014 KZ Spree 262RKS, Reese DC WDH, shocks and Endurance LRE tires
2012 GMC Sierra 2500HD crew cab, Bilstein shocks, heavy duty trailering option
folivier
Southeast Louisiana
Posted: 08/09/19 12:14pm Link  |  Quote  |  Print  |  Notify Moderator
Only issue I can see is when stopping for the night somewhere without hookups you would need to deploy the portable tanks then load them up again. Maybe have a small "day" tank that can handle a couple days, then when parked for longer, use the portable tanks. Maybe combine the 2 different waste sources into 1 valve?
Another option is to use a porta-potty toilet.
2oldman
New Mexico
Posted: 08/09/19 12:20pm Link  |  Quote  |  Print  |  Notify Moderator
For all the reasons stated above, it would be a huge inconvenience. You'd stop taking showers and/or various other toiletries, you'd likely be seeking out public restrooms, dish washing would be restricted...
I wouldn't want to live like that.
BillyBob Jim
US
That's simply opinion. I have never seen in the published rules for any State or Federal Campground I am familiar with, which is more than a few, anything that references RVIA standards or the RVIA at all. The RVIA is a voluntary organization, there are RV manufacturers that do not even belong to RVIA. Are tent campers required to be self contained also.
OP, I have used and dumped a tote tank often. It's not the nightmare folks claim on these boards. Get a 4 wheel tote with a side mounted dump valve. You would not need separate totes for black and gray to do what you describe, you'll be dumping it down the same hole. No one is going to give you any flack or toss you from a campground for having a tote tank connected 24/7.
wowens79
Georgia
Posted: 08/09/19 12:30pm Link  |  Quote  |  Print  |  Notify Moderator
Most pop ups don't have holding tanks. We had one for 9 years, and used a 5 gallon aqua-tainer to catch our gray water. Never had an issue in state parks. I think you might have some issues in some of the private campgrounds. I've seen many of those that don't allow converted trailers or buses, it has to be a factory built RV.
2002 Chevy Silverado 1500HD 6.0l 213k miles and climbing
2016 Heritage Glen 29BH
2003 Flagstaff 228D Pop Up
JRscooby
Indepmo
Posted: 08/09/19 12:32pm Link  |  Quote  |  Print  |  Notify Moderator
Most popup trailers use a cassette toilet or porta-potty as a black tank. (if only restroom wife and I have 2 full days) Also they drain the sink and shower out thru a hose connector and into a jug or tank. I use laundry soap jug for the inside sink, and a 7 gallon jug for the outside sink where I do dishes. Last for 4 days unless it is Thanksgiving weekend.
NRALIFR
Truck Camping Out West
Posted: 08/09/19 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
It is possible to design your interior so that all of your tanks are above the floor. You’ll have to give up some of your storage space to do it though. I’ve had truck campers that were built just like that.
Before TC’s started being built with basements, the standard location for the fresh water tank was above the floor, just below the cabover area inside because you needed a step up there anyway. The TC in my sig has a 30 gallon tank right there.
A previous TC of mine had the black tank sitting above the floor, directly below the toilet that was sitting in the wet bath shower pan, and was about 10 gallons IIRC. There was about a 6” step up into the shower. The grey water did NOT use that tank, and it would last about a week with one person using it, 4-5 days with two people. Our current TC has an 18 gallon black tank below the floor, and it will easily last a week with two people and have room to spare.
The grey water tanks may be more of a challenge if you want a shower in your trailer as well. There has to be a minimum amount of room below the pan for the drain and p-trap plumbing. You might think about using multiple 6” PVC pipes for your grey water tanks. They COULD be below the floor, and between the rails. They would be more durable than any standard RV holding tank as well.
[emoticon][emoticon]
* This post was edited 08/09/19 01:35pm by NRALIFR *
2001 Lance 1121 on a 2016 F450
patperry2766
Saginaw Texas
Posted: 08/09/19 01:00pm Link  |  Quote  |  Print  |  Notify Moderator
Camco
Get the largest you can handle and if you've got the room, you might consider 2 of them. Spend the $$ on this one with the bigger wheels because it makes hauling to the dump station easier. It also has an adapter that fits on the front that hooks over the ball of the trailer and you can tow it.
If you do go this route, be aware of the height of the dump valve vs the inlet height of the tote. The only drawback to this particular model is that it is tall. On my trailer, the dump valves are lower than the inlet valve so if the campsite is level, it can be hard to get poop to flow uphill sometimes.
cassette toilet
Courage is the feeling you have right before you fully understand the situation
Page of 5
