RV.Net Open Roads Forum: Tech Issues: Leak between Awning holder and RV
 > Leak between Awning holder and RV
ItaskaRV1
West Michigan
Posted: 08/09/19 01:55pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2006 Itaska Navion Motorhome. There is a 1 inch foam rubber seal between the awning and the foor of the RV. At one time it appears the out side edges of the foam rubber suppose to stick to the RV and awning. However, those seals are now cracked. How do I go about resealing this to stop the leak.
Craig
jcsb
Sharonville, OH
Posted: 08/10/19 12:07pm Link  |  Quote  |  Print  |  Notify Moderator
Do not understand your question. Why would the awning be attached to the floor of your RV?
Jim Hunter
Darryl&Rita
Grande Prairie, Alberta
Posted: 08/10/19 12:52pm Link  |  Quote  |  Print  |  Notify Moderator
2006. Awning has arms to hold it up. Lower arm mounts, is my guess. Time to pull the mounts off, and replace the gasket material. I wouldn't try to seal around the existing gasket material.
***UPDATE 2006 3500 SRW MegaCab pulling a 2007 fleetwood 5'er
Bill.Satellite
Full-timer
Posted: 08/10/19 03:52pm Link  |  Quote  |  Print  |  Notify Moderator
I suspect roof, not floor (foor). Fingers will do that!
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
lane hog
Tucson, AZ & NW Chicago Burbs, IL
Posted: 08/12/19 11:23pm Link  |  Quote  |  Print  |  Notify Moderator
Craig
A bead of caulk like Dicor?...
  • 2005 Winnebago "Minnie" 31C (was a three-time Jayco owner)
  • 2012 MasterTow Dolly pulling a 2003 Jeep Liberty (had Ram 2500 CTD, Dodge Durango, Honda Odyssey...)
  • Onan Microquiet 4000, plus 130W solar and Honda EU2000i twins for backup
CharlesinGA
South of Atlanta, Georgia
Posted: 08/13/19 02:30pm Link  |  Quote  |  Print  |  Notify Moderator
The awning is a Horizon model that lag bolts to the side of the motorhome just below the gutter. The bolts thread into aluminum structure behind the sidewall.
Here is the installation and operating instructions for it.
http://bryantrv.com/docs2/docs/operating/aehorizon.pdf
OP may have to remove the entire awning from the MH, clean the area, and install new foam. I am not real familiar with this as my '07 View (same MH) had the awning removed before I bought it and I never reinstalled one.
Charles
