RV.Net Open Roads Forum: Fifth-Wheels: What do I need
 > What do I need
Me Again
Sunbird(Wa)/snowbird(Az)
Posted: 08/11/19 08:31am Link  |  Quote  |  Print  |  Notify Moderator
laknox wrote:
Cummins12V98 wrote:
To be clear when backing into a B&W "IF" the handle comes to the "LATCHED" position ti will NOT come loose. Many times I have backed into mine and the handle does NOT fully close even tho the jaws LOOK to be fully engaged.
Handle MUST be closed/locked!!!
This assumes that you're smart enough to remember to take the f'n PIN out of the hold-open position. [emoticon]
Lyle
I never found a need to lock the latch handle open on our B&W Patriot. The way it works spring tension is enough to hold it almost completely open, as one backs into the jaws I could watch in the camera in the back of the front box and see the handle open completely and then closed completely as the king pin was captured.
An outstanding design on all accounts. In fact, I moved the hitch end of the safety pin chain out onto the handle so it was easier to reach, and would no longer reach near the pivot point.
Cummins12V98
on the road
Posted: 08/11/19 10:08am Link  |  Quote  |  Print  |  Notify Moderator
Lyle
Lyle when Chris texted me about what happened I said "I'm betting he pinned the handle back"
That is way I NEVER pin the handle back. I guess there may have been a couple times I did to keep the jaw open to pull away. BUT I always lock my handle closed as part of my routine. Padlock laying on top of my tool box as a reminder to "lock her up". [emoticon]
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
laknox
Arizona
Posted: 08/11/19 10:38am Link  |  Quote  |  Print  |  Notify Moderator
I had an issue very early on, where I couldn't get the jaws to release =without= the handle being pinned open, so I've always done it. Just got in a hurry and did things a bit out of sequence. Normally, I plug the cord into the truck, then jump into the bed to hook the breakaway cable, latch the hitch and pin in in place. Didn't do that and, well, the rest is history.
Lyle
* This post was edited 08/11/19 05:07pm by an administrator/moderator *
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 62 Year Member
Me Again
Posted: 08/11/19 07:26pm Link  |  Quote  |  Print  |  Notify Moderator
Lyle
I think that if you put just a little forward pressure on the jaws via dropping tranny in drive and then park it will always release correctly. Pressure the other direction would lead to to latch arm not wanting to stay open.
I came close once to dropping the trailer with my Hijacker, I spotted the trailer in the garage, got out put the land gear down and pulled the sliding bar out. Then I decided that the trailer was not in the correct location, raise the landing gear and jumped in and started to move forward when my wife yelled at me to stop.
Chris
Kevinwa
Western canada
Posted: 08/11/19 08:07pm Link  |  Quote  |  Print  |  Notify Moderator
6.7 tow rig wrote:
I know from searches and skimming there are about a million different options as far as hitches, sliders, non sliders, etc. But I am still confused as we have been in a travel trailer for the last 16 years. I have a 2018 Ram 2500 4x4 short bed and am looking at a Grand Design 311bhs. What hitch do I need? I dont want to have cab to trailer contact on accident and want something fool proof. I've seen sliders but also something that hooks to the kingpin on the RV instead? I'm sure it's been asked before but help me please. I am also worried about bed clearance to the rv because my driveway is kind of steep getting in. What if anything do I need to be looking at there?
I have no input on hitches, but do have a cousin that pulls a Grand Design 311BHS with a short bed F-350, He has, on more than one occasion, bent his mid trailer leveling jack in gas stations etc. It hangs pretty low. Just a heads up to keep an eye on this if you go with that model.
Braces
Alabama
Posted: 08/11/19 09:38pm Link  |  Quote  |  Print  |  Notify Moderator
PullRite auto slider
schlep1967
Harrisburg, PA
Posted: 08/12/19 05:12am Link  |  Quote  |  Print  |  Notify Moderator
You won't find a sliding hitch that is much more fool-proof than the Pullrite Superglide. I've been using mine for 9 years and have never not had it latch when I backed under it. Yes, I did just knock on some wood.
As far as your steep driveway, is it angled up or down? Angled down is when you need to worry about bed clearance. Angled up you need to worry about the back end of the trailer. And if the TT you had before cleared that you should be fine with the FW.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
laknox
Arizona
Posted: 08/12/19 09:29am Link  |  Quote  |  Print  |  Notify Moderator
I've seen MHs that have "fold away" jacks and I've always wondered why they wouldn't work on a FW. Either that, or a "compact", telescoping jack. Hell, the factory screw jack in my truck is only about 8" tall, but will jack about 20-24" high. I know that the rear jacks on my FW, right behind the rear tires, always concerns me.
Lyle
6.7 tow rig
kentucky
Posted: 08/12/19 10:12am Link  |  Quote  |  Print  |  Notify Moderator
Well I'm getting cold feet. Too many what ifs, or maybe. Thing I like about the TT is in 30 years of camping never had a camper to truck issue. I'm thinking the Rockwood 8327ss travel trailer may be my next. Thanks for all the replies.
2018 Dodge Ram 2500 Laramie Cummins 4x4
2013 Primetime Lacrosse 318bhs
laknox
Arizona
Posted: 08/12/19 10:44am Link  |  Quote  |  Print  |  Notify Moderator
Don't let stuff here scare you off. When I went looking, I'd already had years of bumper pull towing as well as gooseneck towing. I know that no way in hell was I getting a TT; it was FW all the way for me. I've had 2 "major" incidents in 15 years of RVing. First was learning the hard way that you need to look in the same direction you're backing or you'll take out the back window in your truck and this most recent one. I've seen just as many bent trailer tongues and dented beds and broken taillights from TTs being jackknifed. The stability and overall ease of hitching/unhitching a FW, IMO, far outweighs that of a bumper pull.
Lyle
 > What do I need
