RV.Net Open Roads Forum: Tech Issues: Voltage drop on inverter
 > Voltage drop on inverter
Page of 9
phemens
Montreal, Canada
Posted: 08/12/19 04:49pm Link  |  Quote  |  Print  |  Notify Moderator
Samlex manual says surge rated to 466 amps, so I guess I’d better go with 500a on the fuse. I don’t see much in the way of Class T fuses at 500 on Amazon or am I missing something? See plenty of ANL.
The wiring is fine, I have a run of maybe 1.5 feet of 4/0 from batteries to inverter. I assume i’m Ok with 2/0 between the batteries, would really rather not have to redo all the 2/0 I already made.
Itinerant1, it’s hard to tell from your photo since your cables are all so well managed along the batteries, you’re running 3/0 everywhere?
* This post was edited 08/12/19 04:57pm by phemens *
2012 Dutchman Denali 324LBS behind a 2006 Ford F-250 V10 out of Montreal
1 DW, 1 DD, 1 DS, 2 HD (Hyper Dogs)
1Kw solar, 500 AH LIFePO4, Yamaha EF2000 gen, Samlex 3000w Inverter
bigfootford
Fair Oaks, California
Posted: 08/12/19 05:02pm Link  |  Quote  |  Print  |  Notify Moderator
Gave up on reset-able breakers a long time ago. A 200 amp breaker passing 100 amps was dropping over .1 volts. I use. The fuses.
2000 2500 9.6 Bigfoot,94 F250, Vision 19.5, Mich 245/70XDS2's, Bilstein shocks, air bags/pump, EU2000, PD 9260,Lifeline 100ah, 200W. solar, Morningstar Sunsaver 15A/ display panel, Trimetric, Delorme/laptop, Holux gps rec,led lights, Wave-3 heat.
bigfootford
Posted: 08/12/19 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
Dup post.
Itinerant1
Itinerant
Posted: 08/12/19 05:10pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, neg side batteries to shunt to neg buss, inverter. Pos side batteries to seleniods (part or the ems/cpu), pos buss, classt T, inverter.
Copper bar connecting all batteries in parrel.
* This post was edited 08/12/19 05:27pm by Itinerant1 *
pianotuna
Regina, SK, Canada
Posted: 08/12/19 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
Regards, Don
LittleBill
Scranton, PA USA
Posted: 08/12/19 06:13pm Link  |  Quote  |  Print  |  Notify Moderator
based on the reading from the marine website. it says to fuse for the size of the wire, not for the load on the wire. fuse can cause a voltage drop even when working properly, never thought of that till he mentioned it.
glad to see the voltage drop test worked for you, it found something for me as well. just learned about it a year or 2 ago, and i thought i knew alot of about electricity.
Fuse tutorial.
"#1 Fuses should be sized to not exceed a continuous current of more than 80% of the fuse or breakers rating. Doing so will lead to short fuse or breaker life and the potential for nuisance trips. It also leads to excessive voltage drop across the fuse.
#2 When sizing for charging systems it is often best to use a fuse that more closely approaches the maximum ampacity of the wire. Doing so will still protect the wire but will also result in less voltage drop across the fuse. In other words it will be helpful, from a voltage drop perspective, to use the largest size fuse the wire can handle. Doing so will minimize any added voltage drop across the fuse."
phemens
Montreal, Canada
Posted: 08/12/19 07:59pm Link  |  Quote  |  Print  |  Notify Moderator
If I understand correctly from those charts, the recommended maximum ampacity for 0000 gauge wire is about 300 amps, but the inverter recommends 466 at maximum surge rating. 80% of that is about 372 amps. So I guess I should aim for 400?
time2roll
Posted: 08/12/19 08:10pm Link  |  Quote  |  Print  |  Notify Moderator
Wire is fine. I would go 250 or 300 amp on a class T as it takes a bit of time to open depending on the overload. 200% of rating takes about 60 seconds to open.
ANL is much faster so maybe 350 to 400.
These are Blue Sea graphs
675w Solar pictures back up
Itinerant1
Itinerant
Posted: 08/12/19 08:14pm Link  |  Quote  |  Print  |  Notify Moderator
This is from your inverter manual.
BFL13
Victoria, BC
Posted: 08/12/19 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
If 80% is 466, then you want ampacity of 582.5 for the wire and fuse for that. It is just silly IMO. Your max amps from running say the microwave -130a plus the kettle 90a, and the toaster 90a is 310 and then the furnace comes on for another 10 and run the tap for another 10 so call it 350 to go crazy.
The Vector manual seems to suggest the "surge" rating of the inverter somehow comes from the slow blow ANL fuse. Not sure about that, but the wording seems to say that. If the actual surge ability is from the fuse's time to blow, why should you fuse to the surge rating of the inverter? I don't get it.
Also the wire gauge relates to the length of the wires. Beware of not allowing for both pos and neg return "distances". Those tables are bad for not making clear which length is being counted.
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
Page of 9
