RV.Net Open Roads Forum: Tech Issues: Voltage drop on inverter
 > Voltage drop on inverter
Page of 9
Itinerant1
Itinerant
Posted: 08/14/19 10:44am Link  |  Quote  |  Print  |  Notify Moderator
BLF13 is that site talking specifically to a lfp dropin battery. You realize that within each of his drop in batteries there is bms that is cell balancing and if the cells drift outside their lvd/hvd it will shut his batteries down.
phemens
Montreal, Canada
Posted: 08/14/19 10:54am Link  |  Quote  |  Print  |  Notify Moderator
Yes, that was my going-in premise, that the BMS would take care of any per-battery specific issue.
2012 Dutchman Denali 324LBS behind a 2006 Ford F-250 V10 out of Montreal
1 DW, 1 DD, 1 DS, 2 HD (Hyper Dogs)
1Kw solar, 500 AH LIFePO4, Yamaha EF2000 gen, Samlex 3000w Inverter
phemens
Montreal, Canada
Posted: 08/14/19 10:56am Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
I still think a "circle" bus would be best, with the feed taken from the center of the disk and the 5 batteries equally spaced around the perimeter.
I think that's what I'm doing in essence, if all the cable lengths are the same that's what it works out to, if the diagram doesn't make that explicit.
CA Traveler
The Western States
Posted: 08/14/19 11:02am Link  |  Quote  |  Print  |  Notify Moderator
Based on the diagram I'd make 2 changes:
1. Change the wiring so that there is a maximum of 2 wires on any battery buss bolt.
2. Move the cutoff switch to the negative buss. When it's off then a short (like a wrench) from any positive post or wire to ground will not cause a problem.
2014 Grand Cherokee Overland
Bob
CA Traveler
The Western States
Posted: 08/14/19 11:06am Link  |  Quote  |  Print  |  Notify Moderator
Here's my switch, battery buss bar not needed for balanced connection. AGM batteries so no concern about the shunt location.
[image]Click For Full-Size Image
BFL13
Victoria, BC
Posted: 08/14/19 11:10am Link  |  Quote  |  Print  |  Notify Moderator
No, it was about flooded batts.
Related? Is that rule for the battery fuse to be no more than 18" from the battery on the pos wire.
I was told at a car audio shop (which had big enough ANLs that I was looking for) that this rule came from car crashes. The battery can short and a fire start in the wiring to the audio amplifier (plus the other wires) back in the car somewhere. With the fuse there, only the 18" wire is not protected.
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
CA Traveler
The Western States
Posted: 08/14/19 11:24am Link  |  Quote  |  Print  |  Notify Moderator
Well I can't remember any post of someone actually fusing all parallel batteries. More danger I'm sure walking on my street with no sidewalk.
BFL13
Victoria, BC
Posted: 08/14/19 11:26am Link  |  Quote  |  Print  |  Notify Moderator
Theory vs practice! [emoticon]
phemens
Montreal, Canada
Posted: 08/14/19 11:38am Link  |  Quote  |  Print  |  Notify Moderator
I don't think I'd have room for all that anyways [emoticon] My storage bay is already pretty cramped with all h heavy gauge wiring as it is.
The fuse off the battery bus would be a couple of inches max, no worry there.
I can put the battery cut-off on either pos. or neg., I was always 'told' to put it on the positive side, but the possibility of shorting pos. battery to frame wasn't something I had considered (I do have battery post covers on all connections).
CA Traveler
The Western States
Posted: 08/14/19 11:44am Link  |  Quote  |  Print  |  Notify Moderator
BFL13 wrote:
I still don't understand why he wants the pos and neg links to the batteries to be equal. I get that all the pos links should be equal to each other and all the neg links be equal to each other. IMO the pos and negs do not need to be equal, since it is a circuit.
You are correct.
His method is less wordsmithing. And method 4 would be even more involved explanation.
Page of 9
